What kind of oil should i use?
Old 04-25-2007, 11:49 AM
Ahmad_1290's Avatar
I just hit 176k and i have a leaky rear main seal
what kind of oil should i use?
And should i add lucus? if so how much of it should i use?
Ahmad_1290 is offline
Old 04-25-2007, 11:52 AM
jeff5347's Avatar
Look in the fluids section. There are many write ups and posts on different oils and such.
Oh god i sound almost like Sooner jhahaha
jeff5347 is offline
Old 04-25-2007, 01:03 PM
Cletus
SoonerFan's Avatar
you are learning
on topic...fix the problem. changing oil type wont fix the problem for you.
SoonerFan is offline
Old 04-25-2007, 02:30 PM
Ahmad_1290's Avatar
i know that. Im asking what type of oil i should use for that those kind of miles also should i add lucus? how much of it?
Old 05-08-2007, 09:10 PM
pbn85's Avatar
http://www.barsproducts.com/1050.htm
hope it helps
pbn85 is offline
Old 06-05-2007, 04:04 PM
rays05maxima's Avatar
I used valvoline max life with good results.
rays05maxima is offline
Old 06-16-2007, 07:30 PM
JwaxMax99's Avatar
Can you elaborate on these "good results".?
JwaxMax99 is offline
Old 06-20-2007, 09:35 PM
d00df00d's Avatar
Originally Posted by SLVRMAXX
BAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD idea. Never ever ever use quick fix fluids unless you just want the engine to run another few thousand miles and don't care if it blows up after that, because it seriously might.
If the stuff is sticky enough to find a leak and seal it up, where else is it going to stick and seal up? An oil passage? The oil pump? The oil filter? (HINT: All of those are really really bad places for stuff to get blocked!)
If you have a leaking rear main seal, pull the damn tranny and replace the seal. You might as well also replace the transmission fluid while you're in there; if the car is manual, also replace the clutch, pressure plate, and throwout bearing.
After that, change the engine oil with a good but cheap oil like Castrol GTX. You're going to want to change it after about 2,000 miles because a small amount of the RTV silicone sealant you will use for the rear main seal job will leach into the oil at first. From then on, you can keep using Castrol GTX or switch up to something nicer, like Pennzoil Platinum or Mobil 1. Or, if you really like your car and/or want to drag your oil changes out as much as possible, get Amsoil.
d00df00d is offline
Old 06-21-2007, 06:52 AM
pbn85's Avatar
yea im sorry for recomending that link..my fault. At the time I thought it would help but I take it back
pbn85 is offline
litch
123
01-04-2024 07:01 PM
mclasser
22
11-12-2020 01:58 PM
05RLS2
04-14-2016 11:49 AM
magiconthetire
10-26-2015 09:03 PM
Quick Reply: What kind of oil should i use?
