1st & 2nd Generation Maxima (1981-1984 and 1985-1988) Learn more and share information about the 1st and 2nd Generation Maximas.
Diagnostic Data Link Port....Where is it???? ASAP!!
Old 02-02-2007, 05:27 PM
Mr. Blue Sky's Avatar
Does anyone know where that diagnostic data link port is on the maxima, and what it looks like by any chance? I bought a custom made diagnostic/consult board and would like to connect it to my car to at least take a look at any trouble codes my car is throwing out. I looked and couldn't find it, also I need to find it ASAP, thanks.
Mr. Blue Sky is offline
Old 02-02-2007, 07:50 PM
Drjmaxx88's Avatar
behind center console under drivers side?
Or slightly behind the ciruit breakers by the change holder.
Drjmaxx88 is offline
Old 02-03-2007, 02:24 PM
max95q's Avatar
I just took my ECU out and checked for the codes on it. Didnt need a data link. Data link is easier though
max95q is offline
Old 02-03-2007, 04:48 PM
neo_densetsu's Avatar
I wasnt aware of a Data link CONSULT port on the early ECU's, like the ones in the 2nd gens, I know the later cars, like 3rd gen VE's have those ports, and early Z32's/J30's, and S14 and JDM SR20 S13. I dont think the earlier ECU's have those ports.
I have a Nissan Consult at my school, and the book states that it wont work on the earlier cars, if the consult wont work, no other OBD1 scanner will work.
neo_densetsu is offline
Old 02-03-2007, 08:18 PM
I agree about our car not having a consult port, but as far as I know we do have a diagnostic data link(just for pulling codes, not consult). I may be wrong though
Old 03-23-2007, 08:59 PM
From what i've seen, the same port is used for Consult, and OBD-1 code readers on Nissans with the Consult port. This is how it is in my Infiniti J30.
Dont really need to buy anything fancy to get the codes, just turn the switch and let it blink out the codes, it will give you the same codes with a code reader, so there is no reason for one.
Old 03-23-2007, 10:50 PM
s12_200zx's Avatar
special code reader ?
speaking of which, is there any known way to talk to the first gen maxima ecu other than using a special code reader from nissan ?
s12_200zx is offline
Old 03-26-2007, 12:11 AM
Hmm... never seen a first gen before. There arent any lights on the ECU?
S12 200ZX? shouldnt it be SX? I've got an S12, what year is yours?
Old 03-30-2007, 11:04 PM
s12_200zx's Avatar
I have a 1988 vg30 s12 .
Old 03-31-2007, 10:28 PM
Nice. I just have an 87 CA20E S12, with a welded diff and chopped springs. Drifting madness!
I might put in a VG30ET or CA18DET, or I could even get an FJ20ET. Although I have a KA42DE laying around that would be decent in there.
Old 04-23-2007, 09:08 PM
Archangel1183's Avatar
Its cool to know that our cars have these, I thought only newer cars had them. I can't belive most dealers charge $80+ to check the codes when all they do is connect the reader to that.
Archangel1183 is offline
Old 04-25-2007, 12:09 PM
There is no code reader for the 2nd gens, all you do is check the lights.
Old 04-25-2007, 09:05 PM
Niku-Sama's Avatar
acually i have plugged into the diagnostic port before and had it read codes but it not of ODB anything specs...i used a hellatiously old sun diagnostic computer at my uncles shop...it was probally about as old as my car really but still.
S12's are neat, if i ever got one it would have to be a V6 though, since i finally know my way arround this engine a little bit.
Niku-Sama is offline
Old 04-26-2007, 08:09 AM
HowlerMonkey's Avatar
First generation maximas have no codes.
HowlerMonkey is offline
Old 04-26-2007, 11:23 AM
Sorry for going off topic but for some reason I can't make a new thread. Anyway, does anyone know where the cooland temperature sensor is on a 2nd gen wagon? Is it the one right under the distributor? Thanks
Old 04-27-2007, 02:38 PM
Anybody know any tips to take off the coolant temp sensor? Its right behind the timing belt cover and under the distributor. I'm having a hard time, also what size is it? Thanks
Old 05-08-2007, 08:45 PM
I wouldnt call a SUN machine a scan tool... it's more of a multipurpose diagnostic tool, you can read waveforms from any sensors, vaccum graphs.. etc.. etc... I hate the things... I love Nissan Consult scanners, I just wish they would work on the earlier cars.
JakeOfAllTrades
10-05-2015 10:40 AM
Kyle Lee Cleveland
09-28-2015 09:01 PM
rbaker100
09-25-2015 07:52 PM
Quick Reply: Diagnostic Data Link Port....Where is it???? ASAP!!
