Idle air control valve?
Old 11-13-2006, 03:10 PM
Maximahappy22's Avatar
A week or so ago when navfe (blackwind) was at my house he said that my idle air control valve might be bad and he said the symptoms of a bad idle air control valve were very rough idle and bad low end driving that smoothes out at high rpms... well this is what i am expirencing and was wondering if it is something i could change myself or if it is even the idle air control valve.
thanks for your input,
Alex
(vids soon to come)
Maximahappy22 is offline
Old 11-13-2006, 03:15 PM
Way out West
Cliff Clavin's Avatar
you can take it off and clean it and see if that helps.
I am not sure about the VG one, but on the VE, it has some bends in it that don't allow it to be cleaned very well without removing it.
New gaskets sometimes are kind of hard to come by (for the VE, anyway) so be sure you have them in your hand before taking things apart.
The tend to get gunked up, along with the TB.
Cliff Clavin is offline
Old 11-13-2006, 03:17 PM
"and falling like a rock"
89blackse's Avatar
Correct me if im wrong, but dont you have to make your own gaskets for this...
89blackse is offline
Old 11-13-2006, 03:30 PM
Please dont flame me for this but can someone take a picture of it on the VG... i have no clue of what it is
Alex
*EDIT* Here is the vid of my idle: http://youtube.com/watch?v=Cgu-q6Jukuw&q
Old 11-13-2006, 03:50 PM
¯\(°_o)/¯
Greeny's Avatar
Alex
Greeny is offline
Old 11-13-2006, 03:53 PM
¯\(°_o)/¯
Greeny's Avatar
No...Buy the needed gaskets at the dealer,they are cheap and you will be getting the right part...
Greeny is offline
Old 11-13-2006, 04:00 PM
Ok that is what i thought it was... but if i took it off and didnt replace the old gasket with a new one could that be the problem?
Alex
Old 11-13-2006, 04:04 PM
¯\(°_o)/¯
Greeny's Avatar
I would remove and clean the iacv with throttle body cleaner as metioned above[about $2 a can at the parts store] also clean the throttle body while you are at it..
Greeny is offline
Old 11-13-2006, 04:06 PM
¯\(°_o)/¯
Greeny's Avatar
Alex
Yup,not replacing the gasket could very well be you're problem...
Have you removed the iacv??
Greeny is offline
Old 11-13-2006, 04:08 PM
I did that when navfe (blackwind) was over but didnt replace the gasket on the iacv
Old 11-13-2006, 04:53 PM
92 Max's Avatar
You definetely need the gasket on the VG. You can get one at Schucks for few dollars.
Wait, I take this back. I was thinking of the thermostat housing gasket. The IAC gasket was a dealer item, although you could make one out of thicker gasket paper.
92 Max is offline
Old 11-13-2006, 05:36 PM
Dhunterx's Avatar
Your car is acting almost the way mine is. It just started giving me problems Saturday night, and my dad couldn't figure out what the problem was. We're going to check out the IACV now, and see if that'll fix my problem.
Dhunterx is offline
Old 11-13-2006, 05:43 PM
I miss my VE
VEvolution's Avatar
Would carb cleaner or brake cleaner work for cleaning the IAVC?
VEvolution is offline
Old 11-13-2006, 05:55 PM
¯\(°_o)/¯
Greeny's Avatar
Brake cleaner is waaaay to harsh for the iacv..
And not carb cleaner either,throttle body cleaner
Greeny is offline
Old 11-13-2006, 06:02 PM
When we cleaned mine we used the throtle body/carb cleaner could it have messed it up? also didnt change the gasket
Old 11-13-2006, 06:11 PM
¯\(°_o)/¯
Greeny's Avatar
Yeah,i have seen that combo/spray at the parts store,it is safe enough to use on tb's,and will still clean a carburator..
Greeny is offline
Old 11-13-2006, 06:23 PM
Will's Avatar
Those of you who removed your IACV to clean, did you simply unbolt the thing, spray clean, new gasket on, and then put back and fire up?
I was looking at my Hayne's manual on removing this thing back in the summer, and recalled reading about a detailed process where the flap has to be in a certain position when re-installing etc. Is there a write-up? TIA.
Will is offline
Old 11-14-2006, 10:01 AM
I miss my VE
VEvolution's Avatar
I didn't see it on the shelves at AZ when I skimmed through the other day
Old 11-17-2006, 12:53 PM
redwood_usa's Avatar
your problem might also be a egr valve that is stuck open a bit. due to carbon buildup. remove clean and replace, an easy diy job.
redwood_usa is offline
Old 11-17-2006, 02:49 PM
which one is the egr valve? *puts on flame suit*
Old 11-17-2006, 02:55 PM
¯\(°_o)/¯
Greeny's Avatar
Before i get a pic,have you tried any of the previous advice given?
Greeny is offline
Old 11-17-2006, 03:33 PM
yeah it didnt work
Old 11-17-2006, 03:36 PM
¯\(°_o)/¯
Greeny's Avatar
Greeny is offline
Old 11-17-2006, 03:40 PM
ok got it off and leting it soak in tb cleaner for a couple hours.
Smackasmith
02-01-2016 12:40 AM
Starrider
12-18-2015 04:43 AM
tgreen
10-18-2015 06:18 PM
dcam0326
09-07-2015 07:26 AM
03VQMAX
09-05-2015 03:47 PM
Quick Reply: Idle air control valve?
