Engine just shut off at idle!
Old 09-04-2006, 01:22 PM
mastajonjon's Avatar
Hey there I was drivin my bro's 5th gen and suddenly the engine shuts off at idle...I have a 4th gen and never had this problem before...i don't think it's the starter but maybe the ignition harness? I have no idea so any input would be appreciated. Thanks in advance
mastajonjon is offline
Old 09-04-2006, 01:23 PM
retired moderator
irish44j's Avatar
not sure what the starter could have to do with it. The starter only does anything when the car is being.....started.
Did any warning lights come on? could be a bad alternator, bad MAF.....
irish44j is offline
Old 09-04-2006, 06:49 PM
VqMoNsTeR's Avatar
Does the car turn on then cut off? Does it turn over when u try to start it? If it runs then cuts off unplug the maf meter plug then start the car. If it runs and idles its the MAF....
VqMoNsTeR is offline
Old 09-04-2006, 07:27 PM
retired moderator
irish44j's Avatar
concur.
btw, what's up with "The Fastest N/A 5.5 Gen"....I hope you're not serious. Not on those heavy stock wheels
irish44j is offline
Old 09-04-2006, 10:23 PM
getbigtony's Avatar
check battery connection and test battery, make sure there are no intake leaks of any sort
getbigtony is offline
Old 09-04-2006, 11:41 PM
Maximaum Driver's Avatar
I never saw that test for the MAF. I just took a chance when mine started dying for no apparent reason (it was the MAF).
Maximaum Driver is offline
Old 09-05-2006, 05:25 AM
jballa2KSE's Avatar
Does this happen idle in drive, or in park? My 2000 used to die when it was in park and neutral. I replaced the IACV and never had the prob. again. I also heard that you can just clean the IACV, but i repl. instead. Might want to take a look at that if it dies in park. Mine never died in drive.
jballa2KSE is offline
Old 09-05-2006, 05:38 AM
VqMoNsTeR's Avatar
Dont race on these, i have a set of SSR's for you... how bout u make a trip to MD and SEE ME!!
3.No :-)
Old 09-05-2006, 06:36 AM
khynex's Avatar
check ur coils! i missed placed 1 of the parts in 1 of the coils because it came loose and i had this problem...i just put it where it went and i was good 2 go...
u on the othe rhand may have a bad coil
khynex is offline
Old 09-05-2006, 10:49 AM
thanx for da replies...it actually cranks up fine...then when i drive it's fine. but when i'm at a signal whether i'm in drive, neutral, or park, it just shuts off. very strange. I think it's a problem with the idle or something but i guess i'll try the maf or da coils. but i think the maf and coils make the car shutter and then die, but mine just dies silently. I don't even know it died until i gas it and the car doesn't move! any more input would be great!!! i'm sick of my car just dying!
Old 09-05-2006, 10:56 AM
CCS2k1Max's Avatar
First, clean the TB (if it's 5.5 gen, do not move the butterfly). If that deosn't work, check the MAF.
CCS2k1Max is offline
captchaos
17
03-15-2016 12:18 PM
fastcarny
10-06-2015 10:42 AM
EdRomo86
09-12-2015 07:49 PM
NissanNismoZ
09-12-2015 07:30 AM
Quick Reply: Engine just shut off at idle!
