Why is my strut almost touching my tire?
Old 07-24-2006, 01:44 PM
5th Gen till she dies!
ManualMaxima's Avatar
i have k-sports, and i am not to low about 2 inches. and i went to get an alignment today? He said he coudl not do it cause mu strut is aboce 1/8th inch from my tire. I looked and it is!
where my bottom spring pearch is it like about right on the tire. 1/8th inch off. Sorry if this is not a good expenation, but i will try to get some pics.
the guys said it might be a bent spindle? does this sound liek something i culd be or do anyone have any other idea's
ManualMaxima is offline
Old 07-24-2006, 02:35 PM
What size and offset are your wheels?
Old 07-24-2006, 07:10 PM
darklegend06's Avatar
how is the other side? Also it might be your wheels.
darklegend06 is offline
Old 07-24-2006, 07:13 PM
I'm nutty for Nissans
JSutter's Avatar
You may have dialed in all the negative camber with the slotted hole in the strut bolts. It would angle the tire close to the strut if you have set it like that.
JSutter is offline
Old 07-24-2006, 10:15 PM
can you explain more? which bolts? the lower strut mount bolts? sorry just do not understand
Old 07-25-2006, 02:56 AM
What was that?
Caracicatriz's Avatar
There are 4 camber bolts for each of the front shocks. You can see them from under the hood. You can move the shock by loosening the 4 bolts with alan wrenches and just moving the whole assembly. I advise jacking the car up first.
Caracicatriz is offline
Old 07-25-2006, 04:22 AM
JSutter's Avatar
No I mean the 2 lower strut bolts. One of them is oval to aid in camber adjustment. You can try loosening them and pulling the wheel away from the strut. That will give you maximum positive camber, so you'll need to dial it in with the camber plates.
JSutter is offline
Old 07-25-2006, 11:05 AM
okay i will try that, thanks alot man
Old 07-25-2006, 12:07 PM
Blown
cardana24's Avatar
If you do have a bent spindle, then let me know. I have one (I forget what side, but I can check if you need it)
cardana24 is offline
Old 07-25-2006, 01:52 PM
Conecarver
BEJAY1's Avatar
If you don't correct with the plates it'll look something like this.
BEJAY1 is offline
Old 07-25-2006, 06:45 PM
that si what i thought you were aying, i got out there and did it, and i looks better but not the best, but it is much better than it is, and it makes me feel alittle safer.
cardana which one is it and how much you askin?
BkGreen97
04-02-2016 05:47 AM
Luigi623
09-21-2015 01:42 PM
dvcamp
09-18-2015 10:17 AM
dcam0326
09-08-2015 11:02 PM
Quick Reply: Why is my strut almost touching my tire?
