1st & 2nd Generation Maxima (1981-1984 and 1985-1988) Learn more and share information about the 1st and 2nd Generation Maximas.
Rusty water in my radiator
Old 03-12-2006, 12:32 PM
Mr. Blue Sky's Avatar
Recently I have been noticing that the water in my radiator gets a rusty color a few days after I put it in. I did 2 radiator, and coolant system flushes already, but it keeps coming back. Another problem I have is that the fluid level slowly gets lower and lower, enough so that every few weeks I pretty much have to refill most of the water in the radiator. There are no leaks in the coolant hoses anywhere in the engine bay, or anywhere else. I am just wondering if the latter is tied to the former. Any ideas?
Mr. Blue Sky is offline
Old 03-12-2006, 04:24 PM
TylerW's Avatar
Check closer for leaks. If you are losing fluid that quickly you MUST have a leak somewhere.
The rust points to a radiator problem. Maybe you have a small hole in it somewhere. It take a closer look at it. If all else fails, drain out all the fluid and pressure test it.
TylerW is offline
Old 03-12-2006, 10:02 PM
I love lamp.
maximase86's Avatar
How does your oil look. Does it look chocolate shake like? I agree with Tyler on the radiator. You're definately leaking coolant somewhere, or boiling it off to the atmoshpere somehow.
S
maximase86 is offline
Old 03-13-2006, 03:05 PM
Sarin: I suspect it is somehow boiling off the water, because me and my dad have checked as many lines as we could see (water pump is new, so didn't check that) and we saw no leaks, whether the car was on or it was off.
Old 03-13-2006, 03:34 PM
I love lamp.
maximase86's Avatar
How does your oil look? Is there the smell of antifreeze in the car?
It's either boil-off or it's leaking thru the head gasket. The coolant has to go somewhere. You should do a pressure test of the cooling system.
S
Old 03-13-2006, 09:23 PM
S
no antifreeze in the oil and no antifreeze smell in the car. How do I pressure test the cooling system again?? still wondering how the engine is boiling off the water so fast
Old 03-14-2006, 10:33 AM
TylerW's Avatar
Well I kinda offered that as a joke AND a last resort, but you would have to plug one end of the radiator while supplying air to the other to see (hear would be a more appropriate word) if there are any leaks in the radiator. It would be similar to how turbo cars pressure test their intake systems for boost leaks.
TylerW is offline
Old 10-15-2006, 12:15 AM
2daywasag00dday's Avatar
i need to change my radiator tank to man the radiator got a good leak on it, and my powersteering has a rusty watery mixture to it... damn!
2daywasag00dday is offline
hcarter1112
42
07-18-2022 03:35 PM
aw11power
10-10-2021 04:57 AM
Miket2006
03-01-2021 03:55 AM
uttadms31
09-30-2015 05:24 AM
Quick Reply: Rusty water in my radiator
