how to take gas out of gas tank
Old 12-26-2005, 12:59 PM
ray_289's Avatar
anyone no how to siphon out gas out of the gas tank
i need to empty da gas out of my 87 because i just got a new fuel pump..so i ran a 5ft tube through the hole ware the fuel pump used to be(which is under the backseat) but i cant figure out how to get the gas out..any ideas?
thanks i figured i'd get more responses here than the 2nd gen forum
ray_289 is offline
Old 12-26-2005, 03:43 PM
wetzelman1's Avatar
suck hard on tube, hope you don't swallow any.
wetzelman1 is offline
Old 12-26-2005, 03:49 PM
z32drifter's Avatar
well you have the hose, you need a container to put the gas in. Put the hose in the tank and suck on the other end. NOTE you may get gas in your mouth if your not careful. The trick is to get the gas up and out of the tank and headed down hill to your container, once the gas is moving it will do the job from there. Make sure that you keep the tank line under the gas in the tank.
z32drifter is offline
Old 12-26-2005, 06:24 PM
ray_289's Avatar
i did that today..but only a little came out..iam too scared its gonna ggo in my mouth...is there any other way i can take out
ray_289 is offline
Old 12-26-2005, 06:31 PM
Blackbob's Avatar
Well you see if you go to advance autoparts we these nifty little tools right. Well it's a two ended hose with a hand pump for like five bucks and all it does is
syphon gas out of tanks for you.
Blackbob is offline
Old 12-27-2005, 07:51 AM
Nations 1st 6th Gen Turbo
chernmax's Avatar
And no smoking...
chernmax is offline
Old 12-27-2005, 12:04 PM
ray_289's Avatar
thanks i dont have advance around here would pep boys or strauss have it?
ray_289 is offline
Old 12-27-2005, 06:48 PM
Blackbob's Avatar
They should
Blackbob is offline
Old 12-27-2005, 07:14 PM
tilly's Avatar
Hey
Ahh come on, pumping it out with a hand pump is no fun. I had to syphen the gas out of my motorcycle the old way. Gasoline doesnt taste that bad actually it doesnt taste like anything. Make sure if you do get gas in your mouth, spit it out and then get a breath mint preferablly a couple altoids should do the trick.
Good Luck
Tilly
tilly is offline
Old 12-27-2005, 07:56 PM
Z
NYPD-Arnold's Avatar
Just don't smoke a cigg right afterwards.
Just sayin. :|
NYPD-Arnold is offline
Old 12-27-2005, 08:35 PM
TurboS13Hatch's Avatar
You guys are nuts.. I'd never syphon with my mouth...
An easy way to do it...
put your finger over the end of the hose(out of the tank).. pull up on the hose a little (the end in the tank)
uncover the end that your finger is holding closed (out of the tank).. and push down quickly on the hose.. (the end in the tank)..
Do this rapidly for about 10 seconds.. then, quickly hold the uncovered hose-end at the ground outside the car.. the fuel should begin to flow out. The way it works.. is by making a suction (while your finger is over the hole).. and no suction when you uncover the hole.. if you do it fast enough.. and you don't pull the hose completely out of the fuel in the tank while doing it.. it works just fine.
Travis
TurboS13Hatch is offline
Old 12-28-2005, 10:39 AM
Driving is the next best thing
DrKlop's Avatar
Just like everyone else I’m ganna present my method:
1. get a bucket which is lower than the lowest point of you gas tank
2. stick the hose into the gas tank
3. suck gasoline out with your mouth until the hose gets completely filled with gasoline. Don’t worry about getting gasoline in you mouth, unleaded fuel is not harmful. Just wash you mouth in case it actually happens.
4. close the tip of the hose with you finger and put it down in the bucket
5. After you open up the tip all the fuel will come out in the bucket.
DrKlop is offline
Old 12-28-2005, 10:50 AM
I'm needing a caw
Jeff92se's Avatar
Just spend the $6.99
http://www.harborfreight.com/cpi/cta...emnumber=93290
Jeff92se is offline
Old 12-28-2005, 02:00 PM
Blackbob's Avatar
Travis
I would never thought of that
Blackbob is offline
Old 12-28-2005, 05:19 PM
Back from the dead
RockfordMax's Avatar
haha try siphoning out of a lawn mower. basically i put it on top of 2x high stacked milk crates, (fun doing that :-/ ) and it was a lawn boy. oil + gas = tastes bad. listerine wins.
RockfordMax is offline
Old 12-28-2005, 09:03 PM
bigEL's Avatar
You could also try filling the tube with gasoline first. Then plug one end with your finger and hold it near the bottom of your bucket. Stick the other end of the tube into your gas tank as far as it will go. Release your finger from the end in the bucket and watch the siphon go. The gasoline that you originally put into the tube will flow out, creating suction that draws the rest of the gasoline out of your tank. As mentioned before, make sure the outlet end of your tube is lower than your intake end. If that doesn't work and you can't find a hand pump, I'd suggest just driving your car until it's dry.
bigEL is offline
Old 12-28-2005, 09:30 PM
Custom User Title
Nismo3112's Avatar
Sorry if I missed it, but why do you have to emtpy your gas tank when replacing the fuel pump?
Nismo3112 is offline
Old 12-28-2005, 11:18 PM
chernmax's Avatar
Or get a clear hose, when you see the fuel coming, quit sucken...
I have never seen anyone die from sucken gas (OK one time, however the fool was smoking at the same time) and I grew up during the 70's gas crisis when it was a daily occurance. And a way of life...
chernmax is offline
Old 12-29-2005, 05:58 AM
minsbang's Avatar
just goto the ghetto and scream out "does anyone want free gas?" and you'll see a line of peeps with their own methods to get them.
minsbang is offline
Old 12-29-2005, 08:58 AM
GBAUER's Avatar
My tank usually drains as I drive it around....
You don't have to drain the tank to take out your pump. Take out the back seat and you'll see what you need to do from there. Not a tough job and you can keep your mouth minty fresh while you do it!
GBAUER is offline
Old 12-29-2005, 09:09 AM
Custom User Title
Nismo3112's Avatar
That's what I thought.
Old 12-29-2005, 09:26 AM
FrostMaxima's Avatar
Just Drop a Match into the tank and burn out the gas!
FrostMaxima is offline
Old 12-30-2005, 07:26 PM
T-ryks's Avatar
Wal-mart sells electric (2 D batteries) siphoners for about 5 bucks. They're slow but they work good.
T-ryks is offline
Old 01-05-2006, 08:01 AM
Warik's Avatar
Um, why not just use a clear hose and suck STANDING UP until the gas is a few inches away from your lips?
If you are standing up, gravity is working in your favor (at least, to keep you from swallowing gas) since it's not going to flow out.
Now that you have the tube almost full of gas, bend the part by your mouth in half so that the air is cut off and it doesn't flow back down the tube. Now just put it in the bucket and let the gas flow out.
It's the same principle behind draining large fish tanks except it's a little easier with tanks since you can fill the tube up by putting it int he tank first.
Actually... those tubes would work best. They are clear and easy to bend. You can get one from your local pet store for less than $5.
Warik is offline
Old 01-05-2006, 08:08 AM
MDeezy's Avatar
all this sucking just to replace a fuel pump . . .
Just run your tank pretty low (atleast 1/4 left) and then change the fuel pump
No need to blow your car just to change the fuel pump
MDeezy is offline
Old 01-05-2006, 06:27 PM
Warik's Avatar
"ohhhhhhhhh honey!!!! I've got a job for youuuuuuuuuuuuu!!!!!!!"
Warik is offline
Old 01-05-2006, 06:34 PM
DrKlop's Avatar
I took out the whole assembly with my gas tank more than half full.
DrKlop is offline
mclasser
22
11-12-2020 01:58 PM
maxinout93
10-31-2015 02:04 AM
ef9
10-04-2015 08:43 AM
Quick Reply: how to take gas out of gas tank
