Rotors resurfaced at Autozone?
Old 12-18-2005, 08:11 AM
WaarrEagle's Avatar
Has anyone had their rotors resurfaced at Autozone? They have signs up that they do it for cheap but I was wondering if they have good equipment, etc? Any good/bad experiences?
WaarrEagle is offline
Old 12-18-2005, 08:12 AM
Tha Snatcher
Iron Scimitar's Avatar
wow, i've never heard about that...well, not around my parts.
Iron Scimitar is offline
Old 12-18-2005, 09:02 AM
Getting back to his roots
Mizeree_X's Avatar
I think it varies store to store. None of the Autozones I frequent offer it, but there is a NAPA nearby that does.
Mizeree_X is offline
Old 12-18-2005, 09:05 AM
Need A Light?
steven88's Avatar
How much do they usually run for?
steven88 is offline
Old 12-18-2005, 09:50 AM
wikidminds's Avatar
ipay $6 to resurface a rotor....but it isnt at auto zone.....
wikidminds is offline
Old 12-18-2005, 10:43 AM
MDeezy's Avatar
never hard of autozone doing it.
I wouldnt know wheather to trust them or not.
MDeezy is offline
Old 12-18-2005, 10:46 AM
GBAUER's Avatar
Depends on the autozone. I used to live in Michigan City, Indiana and that one did a good job at resurfacing rotors. I wouldn't trust one out here, though (in MD).
GBAUER is offline
Old 12-18-2005, 11:14 AM
Z
NYPD-Arnold's Avatar
Any drawbacks to resurfacing? How much does it typically cost?
NYPD-Arnold is offline
Old 12-18-2005, 11:50 AM
MDeezy's Avatar
No real draw backs. You'll have a smoother surface, so your braking should be better/smoother (assuming your rotor surface is a little uneven). You can only resurface so many times before you'll need a new rotor.
MDeezy is offline
Old 12-18-2005, 12:41 PM
$6 bucks at Napa.
A rotors min. thickness is stamped on the edge someplace. If the rotor is larger then the min. thickness, it can be resurfaced.
Old 12-20-2005, 04:48 PM
Say Candyman 5 times
CandiMan's Avatar
Does it really matter where you get it done, Autozone, Napa, Pepboys, dealer, etc? No it doesn't. What matters is the person behind the lathe. Does the person take his time to remove the bare minimum on each pass regardless of how long it takes and not to over heat the cutting bit? Or is he aggressive on each pass so he can get to his next job? Does he take the time to remove and rust that might be in the center bore of the rotor before mounting on the lathe? Does he take the time to apply a sanding disc on the rotor surface after it's been resurface in order to get a nice cross-cut pattern? This person can work at anyone of those places, likewise yahoos unlike him can work at these places also.
CandiMan is offline
Old 12-20-2005, 09:19 PM
carsarecool's Avatar
I work there, i know we dont do it anymore and havent for a while but its a NY store, im not sure if all of corporate stopped it or left it up to the district managers/store managers to decide
carsarecool is offline
Old 12-21-2005, 06:13 AM
chilled's Avatar
We haven't offered that service in my district for years.
chilled is offline
Old 12-21-2005, 06:55 AM
your a district manager?
Old 12-22-2005, 12:50 PM
ThurzNite's Avatar
Yeah, my local autozone and kragen used to do machine work like resurfacing. They send it to a local garage to get it done. If you wanna save some bucks, goto a garage directly. If you want convenience, autozone/kragen should be ok. pepboyz near me does it in-house.
Jae
ThurzNite is offline
Old 01-05-2006, 08:53 PM
Tenn05's Avatar
Most of your big chain parts places that do do it are very strict on thickness tolerances, mostly because of insurance purposes. We now have a brake lathe at our repair shop, and my dad is particular with his stadegy of doing them. The minnum thickness is the key for them not to re-warp in a short amount of time. The thinner they are the easier they warp. Try to find a reputable place if u want to resurface and if you decide to replace BEWARE of the CHEAP line rotors. There material is crappy and u will be unbolting them again in no time. Stick to USA made, they have proven to be better from what we have seen.
Tenn05 is offline
Old 01-05-2006, 09:25 PM
MDeezy's Avatar
hope they charge in the $10 a rotor area when I want mine milled down.
If these local stores offer a warantee with their work, then I would give them a try, and keep my eye on the rotors for any problems.
MDeezy is offline
BPuff57
04-16-2020 05:15 AM
BkGreen97
04-02-2016 05:47 AM
Socalstillen
09-26-2015 12:01 PM
beerman1378
09-08-2015 02:19 PM
crazyespn
09-03-2015 01:30 PM
Quick Reply: Rotors resurfaced at Autozone?
