How to turn off ABS light ?
Old 11-09-2005, 07:52 PM
goldtooth's Avatar
I was having tooooooo much fun with the maxima and I have developed the ABS light to stay on. I have tried resetting the ECU but its still there.
Any ideas? Please help me quickly. (its not my car, but they dont know yet. lol)
goldtooth is offline
Old 11-09-2005, 07:54 PM
culejoe's Avatar
hmmm new one on me lol
culejoe is offline
Old 11-09-2005, 07:56 PM
'Trynna' is not a word
mtrai760's Avatar
The ABS computer is seperate from the ECU Screwing around in someone elses car = The info you need is all here on the forums, you just have to search
BTW, this has been posted at least 3-4 times in the last 2 weeks alone.
mtrai760 is offline
Old 11-09-2005, 08:04 PM
goldtooth's Avatar
I just did the poor mans search and found that I have a high chance of being . Ohh man , Im so screwed. But is ther any other alternative other than replacing the abs sensor, or cleaning it ? Like a quick fix or check or something that just might work ?
Old 11-10-2005, 07:54 AM
goldtooth's Avatar
bump......
Old 11-10-2005, 08:00 AM
No more Maximas...
pmohr's Avatar
Originally Posted by goldtooth
bump......
Have you run through the ABS diagnostics to see what's wrong?
pmohr is offline
Old 11-10-2005, 01:28 PM
goldtooth's Avatar
No, and how would I proceed to do this anyway?
Old 11-10-2005, 01:42 PM
Team Ramrod
lilaclucymaxima's Avatar
Buy a Haynes manual and read it.
lilaclucymaxima is offline
Old 11-10-2005, 01:43 PM
goldtooth's Avatar
found it!, but what does a parcel shelf mean in the maxima ?
Old 11-10-2005, 01:44 PM
goldtooth's Avatar
heres the link I used for reference
http://forums.maxima.org/showpost.ph...53&postcount=1
Old 11-10-2005, 02:27 PM
I'm nutty for Nissans
JSutter's Avatar
rear deck, you know were the speakers are.
JSutter is offline
Old 11-10-2005, 02:29 PM
No more Maximas...
pmohr's Avatar
That's for the 3rd gens, not us.
Give me a second, I'll pull the info from my Haynes.
pmohr is offline
Old 11-10-2005, 02:34 PM
No more Maximas...
pmohr's Avatar
Drive the Max above 20 MPH for a few minutes, stop and turn off the engine.
Ground the 'L' terminal on the Consult connector , behind the fuse panel cover to the lower right of the steering column.
Turn the ignition to on, and it'll start flashing the ABS trouble code.
It'll flash once, pause, and twice again (code 12) to indicate it's starting code playback.
Then interpret the codes just as when pulling a CEL, except there are no long/short flashes, they're all the same length.
Post the code you get back up here, too many to type out.
pmohr is offline
Old 11-10-2005, 07:27 PM
goldtooth's Avatar
hmmmmm, I got in the car today and the light was gone all day. Does that seem odd? (not that Im complaining or anything...)
tsi6001
10-03-2022 10:23 PM
AnsonJ
06-02-2017 01:35 PM
VerzOphion
08-28-2015 07:57 PM
2k0to2k3
08-18-2015 09:59 AM
kirkhilles
08-08-2015 10:53 AM
Quick Reply: How to turn off ABS light ?
