PO745 and a harsh 1-2 shift? ('97)
Old 10-22-2005, 10:53 AM
jvienneau's Avatar
My '97 Maxima just started shifting hard from first to second and set a code of PO745 which is something about line pressure. Anyone been here before? It has 157K on it, but she's been well maintained and the trans fluid has been changed several times.
jvienneau is offline
Old 10-22-2005, 11:13 AM
cefiro8701's Avatar
do u have the drop resitor mod?
cefiro8701 is offline
Old 10-22-2005, 04:11 PM
jvienneau's Avatar
No, but I just measured the resistor and it's open.
Old 10-23-2005, 04:43 PM
djdirtyrice's Avatar
yes my max shifts hard from first to second, what to do\?
djdirtyrice is offline
Old 10-23-2005, 06:59 PM
jvienneau's Avatar
There's a resistor mounted in an aluminum housing bolted to the driver's side strut housing. Measure it with a multimeter. Should be ~12 ohms if it's good.
Old 10-24-2005, 07:14 AM
Has his VINs memorized
ti2tmax's Avatar
pressure control selenoid A circuit malfunction
ti2tmax is offline
Old 11-01-2005, 12:47 AM
rubo1968's Avatar
My max does same thing it shift 1 to 2 gears when rpm reaches 4500. is if same problem? what should i do?
rubo1968 is offline
Old 11-01-2005, 10:49 AM
GodStrength
can you get a shift kit for a 97 nissan maxima?
Old 11-01-2005, 10:59 AM
f550maranello2's Avatar
There's ur problem.. make sure one more time that the ohm meter shows overload or infinity... if it does just replace the resistor and you should be good because the line pressure solenoid relies on the resistor... if it infact shows 12 ohms you probably need a new line pressure solenoid...
f550maranello2 is offline
Old 11-02-2005, 09:34 PM
eyesack killa's Avatar
my 95 max shifts hard 1-2 ONLY when it's cold (engine temp)... anyone know why? i'd like to check it out with an ohmeter, but how do you use one? sorry im a noob plz i hope this isn't hijacking
eyesack killa is offline
Old 11-02-2005, 09:40 PM
Nissan 6's Avatar
Didnt you get banned for hijacking threads? Your still doing it......do you need another ban to learn your lesson?
Nissan 6 is offline
Old 05-21-2009, 03:18 PM
rneedles's Avatar
PO745 code
I would appreciate any advice from the readers. I have a 1998 Nissan Maxima GLE and the check engine light is on and the Code PO745 (Pressure Control Selenoid "A" Circuit Malfunction) is active. Could someone please explain where this is located and where to order this part from. Any other advice will be greatly appreciated. Thanks.
rneedles is offline
Old 05-11-2011, 10:54 AM
Jowwe's Avatar
I had same problem. Checked drop resistor, mounted on DS shock tower, behind airbox. Had infinite resistance. Replaced it and problem fix immediately.
Jowwe is offline
Old 05-11-2011, 11:54 AM
eddie982's Avatar
Dude's been a member since 05' with 3,594 posts and he's a noob!
2 year necrobumpage! But it is valuable input, I've seen a few posts with same issue, damn resistor.
eddie982 is offline
Old 05-11-2011, 12:02 PM
Jowwe's Avatar
I posted mostly for noobs like myself searching, let em know it worked for me. Dealer tried to sell me $500 solenoid pack, I told em just the resistor. The guy said he never saw one go bad...guess he didn't work there long.
Jowwe is offline
Old 05-11-2011, 12:06 PM
eddie982's Avatar
Were you experiencing hard shifting form 1- 2 only or all gears?
eddie982 is offline
Old 05-11-2011, 12:26 PM
Jowwe's Avatar
Mine was only in 1-2. I know the resistor should affect all gears but I gave it a try and it worked.
Jowwe is offline
Old 05-11-2011, 12:32 PM
eddie982's Avatar
Thanks, good to know. I'm having this **** in all gears, gotta get a used replacement.
eddie982 is offline
Old 05-11-2011, 12:43 PM
Jowwe's Avatar
My symptoms were harsh 1-2 shift, blinking OD light and fault for open circuit in shift circuit A.
Jowwe is offline
Old 05-11-2011, 12:50 PM
eddie982's Avatar
how much did you pay for the new drop resistor from the stealership?
eddie982 is offline
Old 05-11-2011, 12:56 PM
Jowwe's Avatar
$40
Jowwe is offline
Old 05-11-2011, 12:58 PM
eddie982's Avatar
Not too bad, I thought i saw it for $50 + at courtesy.
eddie982 is offline
Old 05-11-2011, 01:13 PM
luke95gxe's Avatar
classifieds i have one for sale and i think maxima joe has one for sale
luke95gxe is offline
Old 05-11-2011, 01:16 PM
cashoit's Avatar
us MT guys dont worry bout no DR mod hehe
lolz
cashoit is offline
Old 05-11-2011, 01:17 PM
luke95gxe's Avatar
lolz
sure dont mine came off my 98 when it got totaled love the option to change my own gears
Unclejunebug
04-02-2016 05:42 AM
hayne
10-05-2015 11:53 AM
ef9
10-04-2015 08:43 AM
Quick Reply: PO745 and a harsh 1-2 shift? ('97)
