Radiator leak + J.B. Weld + ??????
Old 06-27-2005, 04:15 PM
soulrupture's Avatar
Radiator leak + J.B. Weld = Money Saved?
Hello guys my question is this.
How many of you have used J.B. Weld to patch a leak in your radiator?
And how was the result?
History:
I discovered a weeping leak on the top of my radiator about an inch in length. I put two bottles of stop leak ( poor product) and it stop the leak for a couple of hours (Drove 39 miles). Then instead of a weeping leak it was a STREAM of HOT coolent comming out. I put some J.B. Weld on the leak and let it sit for 12 hours. It held for about 39 miles then it was a small drip from the top of where I put the weld. I figured I had not put enough so I sanded everything down and reaplied a more complete aplication.
I'm waiting for a full 24 hours too see if this saves me from buying a new radiator.
Thanks for any thoughts.
P.S.
If your are looking for one here is what I found. 4th gen
http://www.carpartswholesale.com $129.95
http://shop.car-engine-parts.com/nis...5034csf_2.html $152.29
http://www.allnissanparts.net/ $347.27
Kopel nissan in Jackson Hights, New York $500
soulrupture is offline
Old 06-27-2005, 04:36 PM
Jatan's Avatar
http://search.ebay.com/maxima-radiat...fkrZ1QQfromZR8
Jatan is offline
Old 06-27-2005, 04:41 PM
OG
SmoothMax's Avatar
I had the same problem and used the same method you're using to make repairs and it just didn't work. Don't waste your time....get a new radiator.
SmoothMax is offline
Old 06-27-2005, 06:09 PM
JayMAX22's Avatar
Had the same problem with a previous car and just like you, the J.B. Weld was a waste of time. I went out and purchased a new radiator and thermostat and all my problems went away.
JayMAX22 is offline
Old 06-28-2005, 03:06 PM
UPDATE: well all looks ok I will take it out on the high way in an hour or so, to see if the weld holds up.
Old 06-28-2005, 03:08 PM
Kevlo for President
Kevlo911's Avatar
http://www.rockauto.com/catalog/cata...4&partGroup=16
100dolla.
You prob already spent 20-30bucks trying to fix the leak.
Kevlo911 is offline
Old 06-28-2005, 07:57 PM
update 2:
J.B. Weld did nothing for me. It held for 15 minutes then leaked again. "When it goes it goes" You guys were right. Thanks for the links "JaTaN", "Kevlo911" I am going with with
http://shop.car-engine-parts.com/ni...85034csf_2.html $152.29
because they can have the radiator to me in a day. They have a werehouse right in Jersey about an hour from me. 4th of july weekend is right around the corner and I need the car running.
I'm putting it in myself so I'll post how that goes. Wish me luck and thanks for the feed back.
Old 06-29-2005, 01:19 PM
Jatan's Avatar
Should be a straight forward job
Check the hoses - if they need replacing, might as well do it now
Jatan is offline
Old 06-30-2005, 06:37 AM
Eat, sleep, and sh*t 2JZ
DA-MAX's Avatar
are you all letting it cure properly?? I've used JB weld on everything form oil pans to radiators to plugs holes and had it hold for months. though in spots such as the radiator high speed driving for long periods(increased heat) will affect it, normal driving will last for months though.
DA-MAX is offline
Old 06-30-2005, 10:51 AM
"DA-MAX" I first let it set for 15 hours and the second set for a full 24 hours with the same results. I think it has to do with our radiatiors being plastic. On the package it said it will not bound to a certain type of plastic. (I can't remember the name) Maybe thats the same plastic used in our radatiors. Also J.B Weld is rated stable at 500 degrees. Much more then I belive is the heat of the fluid in our raditors, I may be wrong if I am let me know.
Update:
Radatior is in my area should have it by the end of the day.
Old 06-30-2005, 12:52 PM
DA-MAX's Avatar
yeah I forgot they are plastic, I bet that was your problem. I've never used it on plastic before, only metal.
DA-MAX is offline
Old 06-30-2005, 07:49 PM
update:
Well all is well the radiator is a perfect fit and went in with out a hassle. I did an oil change while I was at it. I'm filling her up with coolant tomarrow morning and then I'll check for leaks. All my hoses were fine. One thing that I noticed I'll start a thread about is the loosening of the clips that hold the hoses in place.
Other then that I'm glad I did it myself and can't wait to the max on the road. =)
Old 07-03-2005, 04:11 PM
ColdSHO's Avatar
super glue and a sheet of styreen(spl) plastic, u can fix just about anything that way. i fixed a turtle like that last week, if it can fix a turtle why not a raidator?
ColdSHO is offline
Old 07-05-2005, 07:28 PM
jackiss2888's Avatar
used the jb method, didnt work. got a new rad. and installed it, lol.
jackiss2888 is offline
Old 07-05-2005, 08:24 PM
upstatemax's Avatar
Epoxy???? that crap will hold anything and stand up to heat.
upstatemax is offline
Old 06-03-2009, 06:45 PM
msoler29's Avatar
Pressure
My Impreza did the same thing. I have this little pin hole leak over the stamp where it says Subaru on top of the radiator, and when I tried JB weld it only lasted about 24 hours, then when I drove back home from work doing 70mph the radiator started smoking and the car started over heating"smoke everywhere coming from that little pin hole leak"..... I had a bad feeling the radiator cap was bad, I had to press hard for it to turn onto the radiator, so I changed the radiator cap and the pressure stopped but of course I still have the pin hole.. I'm going to sand down the radiator get all that Jb weld off and try ceramic mix maybe that'll do it, untill I get my next pay check in another week and a half to order a raidator.. Sometimes it's the radiator cap, so try that when you get a chance, the best thing to do is just buy a new radiator online and have it shippped to you in 24 hours. Advance tried to charge me 280.00 for my radiator!!!! are they on crack! I get it online for 99.00 free shipping!!!! damn advance over pricing people.
Well you all have a great day.
msoler29 is offline
Old 06-04-2009, 08:05 AM
wish2345's Avatar
holy back from the dead thread.
wish2345 is offline
Old 06-04-2009, 08:25 AM
I love lamp.
maximase86's Avatar
That's so thoughtful. Thank you!
maximase86 is offline
Old 06-06-2009, 08:00 AM
tigersharkdude's Avatar
Well I had the same problem, used JBweld and it worked
tigersharkdude is offline
Old 06-08-2009, 03:55 PM
Ghost240SX's Avatar
Ummm I wouldn't do it just because if you screw up and it ends up in your coolant system you're ****ed.
Ghost240SX is offline
Old 07-03-2009, 11:45 AM
A33Black's Avatar
Scuffing the plastic area with steel wool, then cleaning the area 100% w/ water then alcohol, will help when the JB needs to adhere to plastic.
Surface preparation is CRITICAL to having a lasting JB fix.
Haven't used it for a radiator fix yet. But have used it to fix a leaking gas tank and broken master cylinder sight glass on a motorcycle. Both fixes are going on 2+ years w/o leaks.
A33Black is offline
hcarter1112
42
07-18-2022 03:35 PM
aw11power
10-10-2021 04:57 AM
Miket2006
03-01-2021 03:55 AM
Unclejunebug
04-02-2016 05:42 AM
uttadms31
09-30-2015 05:24 AM
Quick Reply: Radiator leak + J.B. Weld + ??????
