Disconnected battery = reset ECU memory
Old 06-25-2005, 09:46 AM
dr-rjp's Avatar
I read somewhere that disconnecting the battery resets the ECU's memory of how you drive.
My question is, "Does that happen immediately, or only after a certain period of time?"
I'm installing a new battery and I would prefer NOT to give my ECU amnesia.
dr-rjp is offline
Old 06-25-2005, 09:58 AM
Kevlo for President
Kevlo911's Avatar
No, only way to reset ECU is to use the screw method or Consult. OBDII readers can clear the code.
Batt does nothing.
Kevlo911 is offline
Old 06-25-2005, 09:59 AM
Do I get a tax break?
njmodi's Avatar
I don't know exactly how long you have, but I think its on the order of 30 mins. So you should have plenty of time to swap in your new battery. You will lose radio station presets, clock etc., those are independent of the ECU memory.
njmodi is offline
Old 06-25-2005, 02:57 PM
InsneDrmr's Avatar
how would the car know how you drive?...i mean ive heard of wear in certain spots on the clutch due to the driver, but never anything on the ecu.
InsneDrmr is offline
Old 06-25-2005, 03:58 PM
dr-rjp's Avatar
It's alive! It's alive!
Seriously, the ECU is a computer with a self-learning function that adapts various engine functions to how you drive.
Drive like a granny? The ECU will produce one set of variables to match. Drive like Mario Andretti? The ECU will produce a different set of variables to match.
Now, if we could only get the drivers to be so smart!
dr-rjp is offline
Old 06-25-2005, 04:05 PM
Kevlo for President
Kevlo911's Avatar
Actually the ECU is always learning, every second. There are no presets that it adjusts to. The maps are changing all the time.
Kevlo911 is offline
Old 06-25-2005, 04:38 PM
MIXXMAX's Avatar
Disconnecting the battery long enough will clear all codes if stored in the memory of the ECU. But, this actually does nothing but make the car have to go thru several drive cycles to re-learn everything. If there were codes stored before the disconnection, you can guarantee that it will come back soon if the faulty sensor hasn't been changed. That is why if you change a faulty sensor, and have to disconnect the battery or not, just as long the battery isn't disconnected too long (several hours or so), you should use a scan tool or consult to clear the code so that the car can recognize the new sensor and adjust to it right away. The car will relearn much faster with the new sensor.
MIXXMAX is offline
Old 06-25-2005, 04:46 PM
how would the car know how you drive?....
BMW's learn how you drive.
Their transmission controller actually adapts to your driving style when you drive in the "S" sport mode. If I drive my 330 hard the controller holds the gears longer and doesn't upshift as quickly if you let off the gas for a second. You can very clearly feel it change shift patterns to adapt to the way it's driven.
Old 06-25-2005, 05:06 PM
Kevlo for President
Kevlo911's Avatar
Maxima TCM is not that smart.
Like I said, dissconnecting batt does not clear ECU codes.
Kevlo911 is offline
Old 06-25-2005, 07:54 PM
I Broke OT
86maxima96's Avatar
wow!! i had no idea! that's really cool to know. another great reason why i my maxima!
86maxima96 is offline
Old 06-25-2005, 09:42 PM
cefiro8701's Avatar
no u cant do this....do the ECU screw method...anyways...good luck...i tried the battery thing so many times...it doesnt work...do the screw method...
cefiro8701 is offline
Old 06-25-2005, 09:58 PM
blah
Batxel's Avatar
It does for me. When I did the big 3 upgrade and when I installed my stereo it cleared the codes. I would estimate that you have to disconnect the battery for about 2 hours for it to clear the codes. Also when I went on a trip for two weeks I disconnected the battery and cleared the codes again.
Batxel is offline
Old 06-26-2005, 08:02 AM
Kevlo for President
Kevlo911's Avatar
I bet if you check the codes, the codes are still there
Sometimes the ECU turns the light off but the codes are still in the computer and the light will come back on in a few days.
Kevlo911 is offline
Old 06-26-2005, 08:06 AM
dtm13002's Avatar
You can reset your maximas memory by unhooking your battery cables and hold them together, thus drainging all energy from your car, leading to a reset in your cars memory. Since you do not wish to do this, just simply make sure your + and - are not touching. You have plenty of time.
dtm13002 is offline
Old 06-26-2005, 10:55 AM
njmodi's Avatar
njmodi is offline
Old 06-26-2005, 03:45 PM
blah
Batxel's Avatar
I checked the codes and they weren't there. In my case they were evap codes so whenever I disconnected the battery or reset ecu (screw method) the codes came back about 2-4 days later
Batxel is offline
Old 06-26-2005, 05:45 PM
blah
Batxel's Avatar
njmodi didn't say anything wrong read it again
Batxel is offline
Old 06-26-2005, 05:50 PM
Crockpot's Avatar
you're right, my bad, post removed
Crockpot is offline
gigabyte
01-06-2017 06:05 PM
doctorpullit
03-29-2016 11:08 AM
bigfrank
10-01-2015 12:51 PM
maxima297
09-30-2015 03:32 PM
Quick Reply: Disconnected battery = reset ECU memory
