A/T Solenoid Valve assembly and TCM
Old 06-01-2005, 08:24 PM
cmuehlenb's Avatar
My Infinity has that transmission slip from 1st to 2nd under powered acceleration.
TSB ITB00-028b says to replace the A/T Solenoid Valve assembly and TCM. Has anyone done this and is it a big deal? My car is out of warranty.
Anyone have the part numbers to order the parts?
Thanks.
cmuehlenb is offline
Old 06-06-2005, 06:49 AM
nick's Avatar
check out this thread: http://forums.maxima.org/showthread.php?t=296692
new solenoid assembly cost around $140 from dealer, make sure he sells new the new and improved one, don't let him try to sell you the old one for around $400 !!!!
is your chech engine ligt on? and is your overdrive light flashing at start up?
Nick.
nick is offline
Old 06-06-2005, 08:23 AM
cmuehlenb's Avatar
No check engine light and no code and no flashing light. It actually has a weak shift between 1st and second that I am trying to fix.
It sounds like it was an easy swap. Did you ever get your tranny fixed?
Old 06-06-2005, 08:27 AM
nick's Avatar
yes, my dropping resistor was bad, but i'm glad that I've replaced those shift solenoids
my auto tranny with 145k shifts really good
Nick.
nick is offline
Old 06-07-2005, 03:32 PM
skeetch's Avatar
According to the TSB the new solenoid valve assembly PN is 31940-85x03 ('00-'01). The only noticeable difference between the old and new solenoid assembly, that I saw, was that solenoid A had different enclosure. The TCM part numbers are 31036-3y160 ('00) and 31036-5y001 ('01). Replacing the solenoid valve assembly requires you to drop the VB. It's messy but doable. There are only 13 bolts that need to be removed. Someone posted a how-to on dropping the VB in the Gen5 forum which included a picture showing the 13 bolts that need to be removed.
skeetch is offline
Old 06-07-2005, 03:39 PM
NOCturnalI30's Avatar
I dont see it??????
NOCturnalI30 is offline
Old 06-07-2005, 04:09 PM
skeetch's Avatar
Originally Posted by NOCturnalI30
I dont see it??????
Ooops, it was in the vqpower website...my bad! The instructions show 14 bolts have to be removed (if I remember correctly the bolt that holds the red solenoid B wire does not have to be removed to drop the VB).
http://www.vqpower.com/v2/modules.ph...howpage&pid=60
skeetch is offline
Old 04-07-2009, 09:40 AM
atlas1's Avatar
o/d light flashing
Nick.
hi guys,
i'm a newbe here. what does it mean when my o/d lightflashs(about 16times)mean. any help will be greatly appreciate it.
thank you
atlas1 is offline
Old 01-23-2010, 03:09 PM
Kobeone_24's Avatar
Nick.
Hey im new to this site but, yea im also having problems with the jerking from 1st to 2nd and vice versa. You say to go to the dealer and get a new solenoid assembly for about $140 and not to let them sell you a used one for $400. how would someone know if there selling you a new or used one based on what price they tell you.. i might walk in and ask for a new solenoid assembly thinking its gonna be around $140, maybe a little more and they might end up telling me its like $200 or better. how would i know if im getting jerked around
Kobeone_24 is offline
Old 01-27-2010, 11:15 PM
ZGadson's Avatar
I've had mine replaced once before while the car was under warranty, but sadly, the transmission is doing the typical 1st to 2nd shift jerk. How easy would this be to replace for someone who hasn't done transmission work before?
ZGadson is offline
Old 02-04-2010, 03:33 AM
NismoCefiro's Avatar
Don't mean to sound like a pessimist but 5th gen A33A's have problematic trannies. Im not gonna lie, I did solenoids, then full rebuild with new bands and clutches and vbmod. Crapped out again. I ended up doing the manual swap. Money in this auto tranny is futile.... =\
NismoCefiro is offline
Old 02-04-2010, 06:58 AM
ZGadson's Avatar
As cool as it would be to have a stick again, I'd have to pass on that. Atlanta traffic is a *****, and I'd get fed up with it again. I also don't plan to have this car for more than another year or two, so an auto to manual swap wouldn't be in my best interest at this point. I just don't want it slipping at least until I get rid of it. Then its someone else's problem.
ZGadson is offline
Old 01-03-2011, 10:57 AM
Hackney71's Avatar
I know this is an aging thread; but... 93 infiniti tranny (same as maxima/300z) shifts from 1 to two when in D2. When in D3, 1 to 2 to freewheel with nothing catching. When in D4 shifts 1 to 2 two to freewheel and then torque converter will lock in and continue to power in 2nd and freewheel to coast and catch in 2nd when engine speed matches 2nd gear. when up to maybe 60mph in D4 you can shift down to D3 and you will feel/hear something engage with a little resistance but no gear catching. Any ideas no engine light?
Hackney71 is offline
Old 09-28-2011, 02:00 PM
OJGrier's Avatar
can anyone give me info on how to install a transmission solenoid a 01'infiniti i30?
OJGrier is offline
TKHanson
11-24-2018 01:39 AM
tseng1023
10-15-2015 08:30 AM
hayne
10-05-2015 11:53 AM
atriuum
09-28-2015 01:19 PM
Noela
09-26-2015 08:22 AM
Quick Reply: A/T Solenoid Valve assembly and TCM
