Best Brake Fluid Brand/Type
Old 05-09-2005, 09:54 PM
SmackDown85
What is the best all-around brake fluid brand and type? I live in Florida and I drive somewhat aggressive on roads. Car is daily driver and I like to go fast and stop quick . What can you guys recommend?
Old 05-11-2005, 03:55 AM
aussie983's Avatar
ATE super blue. Peroid.
aussie983 is offline
Old 05-11-2005, 11:35 AM
The Definitive AE Master
Larrio's Avatar
not true.... if you really want the best with high wet/dry boiling point you go race inspired
motul 600
ap racing brake fluid
but since you drive on the street, just go with prestone or ATE
Larrio is offline
Old 05-11-2005, 03:38 PM
Love_00_Max's Avatar
Valvoline Syn DOT3/DOT4 brake fluid which is avaiable OTC.
Love_00_Max is offline
Old 05-13-2005, 06:40 PM
retired moderator
irish44j's Avatar
ATE Super Blue.
you can get it here: www.ogracing.com
irish44j is offline
Old 05-15-2005, 05:05 PM
SmackDown85
motul 600
What do you mean "since you drive on the street" ?
Are you saying just to get ATE because it is cheaper? Is Motul 600 actually better but it's just more money?
Also can you buy Motul 600 locally at auto parts stores?
Old 05-24-2005, 11:00 PM
I miss my VE
VEvolution's Avatar
dot3 STP brake fluid isn't bad. i've been havin a brake fluid leak for a long time, and i buy the cheapest stuff and works great
VEvolution is offline
Old 06-22-2005, 08:26 PM
retired moderator
irish44j's Avatar
ATE blue is a race fluid, technically...it has a very high boiling point. But...it's also good for street use because of low water absorption (many race fluids absorb water quickly)....I've used it for years for both daily drivers and for autocross/road racing cars, never a problem.
The brake fluid will not "make your car stop faster" for regular driving though...the boiling point only really comes into play with constant, repetitive high speed braking.
irish44j is offline
Old 06-23-2005, 10:31 AM
kcryan's Avatar
Alright first off i agree with the vote for Valvoline Syn Dot3-4, i bet that will serve your needs great.
To adress the subject of water absorption, you want your brake fluid to absorb water, although it lowers your boiling point and makes you change it more often, without it your going to have mega rust in your expensive ABS (or non ABS but still expensive) parts.
kcryan is offline
Old 06-23-2005, 12:06 PM
Do I get a tax break?
njmodi's Avatar
Please explain this further... how does water help prevent rust? I would think that as the brake fluid absorbs moisture (since its hygroscopic), the changes of rust is higher with the older fluid, not with fresh fluid... what am I missing
njmodi is offline
Old 06-23-2005, 12:10 PM
I'm needing a caw
Jeff92se's Avatar
The better question is. If the fluid never absorbs water, how would it rust??
I think he's referring to other brake fluids make you change it often as they absorb more water. Thus always having newer fluid in. But he's reasoning is flawed regarding the rust issue.
Jeff92se is offline
Old 06-23-2005, 12:25 PM
Getting back to his roots
Mizeree_X's Avatar
If the fluid didn't absorb water, then the water would form a second liquid phase in your brake lines, and that aqueous phase would probably be more apt to cause rust formation than if the water were absorbed into the brake fluid itself.
Mizeree_X is offline
Old 06-23-2005, 12:46 PM
I'm needing a caw
Jeff92se's Avatar
Well assuming he's using Dot3,4 or 5.5, it will absorb water. Unless you are refering to the all silicone dot 5, which is a no no
And as long as the additives on the fluid are new, it's not a problem. But as the fluid gets old, the additives wear out and can no longer prevent rust/corrision from occuring
Jeff92se is offline
Old 06-23-2005, 09:05 PM
kcryan's Avatar
Thats what i meant, sorry for the confusion.
kcryan is offline
Old 06-23-2005, 09:43 PM
STFU n00b!
Matt93SE's Avatar
hard and fast numbers, so people can stop pissing in the wind:
Wagner 21B DOT 3
Dry, 401 F
no data on wet
Wagner ABS Blend DOT 4
"exceeds DOT 4 standard of 446 F"
Castrol GT-LMA DOT 3/4
Dry, 446 F
Wet, 311 F
Valvoline Synthetic DOT 3/4
Dry, 480 F
wet, 330F
Wagner Severe Duty DOT 5.1
Dry, "over 500 F"
AP Racing AP551 DOT 3
Dry, 527 F
Wet, 302 F
AP Racing DOT 5.1 fluid
Dry, 527 F
Wet, 363 F
(non-silicone based. WILL mix with dOT 3 and DOT 4 fluids)
ATE Superblue DOT3/4
Dry, 536 F
wet, 392 F
AP Racing AP550 "exceeds DOT standards"
Dry 550 F
no data on wet.
Ferodo Formula Racing - DSF 050A DOT 5.1
Dry, 572 F
"WARNING: FERODO FORMULA RACING IS NOT RECOMMENDED FOR NORMAL ROAD USE."
AP Racing AP600 (no info on DOT certification)
Dry, 590 F
Wet, 410 F
NOT suitable for systems with magnesium parts. chemically reacts with magnesium to produce gas. All old fluid must be purged from system and then system flushed with AP600 before being filled completely and bled.
Motul RBF 600 DOT 3/4
Dry, 594 F
Wet, 421 F
Castrol SRF DOT 3/4
Dry, 590 F
Wet, 518 F
AP Racing PRF660 DOT 4
Dry, 608 F
Wet, 390 F
Prospeed GS610 DOT 4
Dry, 610 F
Wet, 421 F
Sources:
http://www.apracing.com/car/brakefluid/dataselect.asp
http://www.speedwaremotorsports.com/access/fluid.asp
http://www.saferacer.com/gsrabrfl.html
http://www.federal-mogul.com/vgn/ima...ageback.OL.pdf
also have several bottles of various brands on hand to read the labels.
Matt93SE is offline
Old 06-23-2005, 10:18 PM
STFU n00b!
Matt93SE's Avatar
Now for a translation of all those numbers..
for street driving, ANY of those fluids will be fine.
for agressive street driving, the Castrol GT-LMA would be the lowest temps I suggest.
for track use, the Castrol GT-LMA is also usually going to be fine for stock calipers and streetable pads (Axxis MM, Hawk HPS, Porterfield R4S, Bendix, Wagner, Raybestos).
for higher temp use where you start to experience pad fade on the above mentioned pads, then I suggest bumping up to the Valvoline Synthetic fluid. for any true BBK or race pad (Hawk HP+ or Black, Axxis Ultimate, Carbotech, Ferodo, Wilwood, AP, Brembo, Porterfield R4 or R4E, etc), then the minimum I suggest is the Valvoline.
I used the valvoline a couple weekends ago at TWS. My 13" wilwood setup had the brakes hot enough to turn my rotor hat mounting bolts blue and melt the wheelweights off the inside of my wheels, and I never experienced brake fade of any sort. They just kept getting better. So honestly, there's not much a Maxima can do on street tires that will need anything above the Valvoline.
If you can boil that fluid on anything but a full blown road course and NOT get arrested doing it, then I'll buy you a can of ATE superblue.
Matt93SE is offline
Old 06-24-2005, 06:57 AM
njmodi's Avatar
Matt,
I think this needs to be added to the fluids/lubricants stickies across all the forums - your last two posts are very informative (to put it lightly).
Thanks!
njmodi is offline
Old 06-24-2005, 07:59 AM
STFU n00b!
Matt93SE's Avatar
Just bored last night and didn't want to go to sleep.
Matt93SE is offline
BPuff57
04-16-2020 05:15 AM
leatherneck
09-30-2015 09:16 PM
HerpDerp1919
09-29-2015 02:02 PM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: Best Brake Fluid Brand/Type
