painted G35c wheels.Pic take a look
Old 05-08-2005, 04:08 PM
Malecki2k3's Avatar
My wheels had some curb rash so I've decided to paint them.Came out to dark and to grey but I like it. I'll try something brighter at the end of the summer.Tell me what you think
http://www.cardomain.com/memberpage/836416
<IMG http://www.cardomain.com/memberpage/836416>
Malecki2k3 is offline
Old 05-08-2005, 04:31 PM
SHIFT_om nom nom nom
Metal Maxima's Avatar
Not bad
Metal Maxima is offline
Old 05-08-2005, 04:33 PM
retired moderator
irish44j's Avatar
Here's how you post the pics....looks ok, but what kind of paint did you use? On an alloy finish, it won't stick very well for extended periods...The color is ok, though it doesn't really match your car all that well, at least in the pics...
irish44j is offline
Old 05-08-2005, 04:35 PM
Puppetmaster's Avatar
Sorry... not feeling the color scheme there... doesn't really flow with the rest of the car...
Puppetmaster is offline
retired moderator
irish44j's Avatar
for comparison's sake:
irish44j is offline
Old 05-08-2005, 04:42 PM
04BlackMaxx's Avatar
If you went darker it'd look nice.
04BlackMaxx is offline
Old 05-08-2005, 04:44 PM
ChromeSE5's Avatar
not feelin it... looks like primer tell you the truth. maybe add some metal flake or something... but it doesnt go well with a gold maxima.
ChromeSE5 is offline
Old 05-08-2005, 04:46 PM
Kevlo for President
Kevlo911's Avatar
Should have done GunMetal or left it alone.
Kevlo911 is offline
Old 05-08-2005, 05:03 PM
vicodin ... gift of life
nadir_s's Avatar
the work u did looks good.
were the tires removed from the wheels when u worked on it?
i am considering very hard to re-finish my OZ wheels because the clearcoat is failing and there are spots all over it.. i was going to go with the exact color you have right now. What products did you use? how'd you do it?
I've seen some writeup about using airplane stripper -> sanding ... let me know, thanks
nadir_s is offline
Old 05-08-2005, 05:08 PM
Malecki2k3's Avatar
It will look better , next time I'll try some bright silver.I 've used acrylic enamel paint and it sticks ok
Old 05-08-2005, 05:11 PM
Puerto Rico-Maxima Lover
Lontar1's Avatar
I like the color .. .. Great job on the wheels
Lontar1 is offline
Old 05-08-2005, 05:13 PM
BRAN808's Avatar
Painted G35's
I was considering painting mine as well. Sorry, but I'm not feeling the color. Well, I guess the color is ok, but not quite on a gold car. Just my opinion. I wasnted to spray mine bronze for my Icelandic Pearl Max. I may do it over the summertime. Just waiting to find some new wheels, then I'll take mine off and spray the G's.
BRAN808 is offline
Old 05-08-2005, 05:36 PM
TheBigDu's Avatar
It doesn't look bad, but it's not as nice as before. The paint needs more of a metallic lustre.
-Brian
TheBigDu is offline
Old 05-08-2005, 07:22 PM
TenetMusic's Avatar
maybe make it glossy...it looks to flat
TenetMusic is offline
Old 05-08-2005, 07:42 PM
PHSINVENT's Avatar
Hyperblack or Alumifec
You need to get a hold of our hyperblack paint or Motochrome. Alumifec would also work well if you want a satin finish. We repaired a set of G35 wheels before and we had to use our alumifec to match because our motochrome was too brilliant.
www.motostorm.com
PHSINVENT is offline
Old 05-08-2005, 07:46 PM
XGaSpAcHo
it doesn't look bad but i like the way they look from the factory more.
Old 05-08-2005, 08:16 PM
Teufelhunden's Avatar
its not that bad, but you need more clear coat? its not shiny at all. yeah you should try darker, itll look nice!!
Teufelhunden is offline
Old 05-08-2005, 08:18 PM
Malecki2k3's Avatar
I'm going to try Alumifec thats for sure.Thanks PHSINVENT
Old 05-08-2005, 08:38 PM
PHSINVENT's Avatar
Alumifec is basically our satin chrome finish. It is used to create the look of real metal. If you want a more reflective finish then i'd suggest the motochrome or hyperblack(black chrome). You can also control the level or brightness of each of these paints just by changing the base coat color.
Old 05-13-2005, 08:23 PM
oxygen's Avatar
The car looks very depressed.[with current color scheme] ...the wheels just don't go with a Maxima, I'm sorry.
oxygen is offline
Old 05-13-2005, 08:29 PM
upstatemax's Avatar
Advanced Auto has a wheel clear coat with a metal flake in it. give it a try, it will shine the rims more and give it that great sparkle.
upstatemax is offline
litch
123
01-04-2024 07:01 PM
BPuff57
04-16-2020 05:15 AM
doctorpullit
04-23-2017 05:35 AM
REDinLV
10-18-2015 05:31 AM
Luigi623
09-21-2015 01:42 PM
Quick Reply: painted G35c wheels.Pic take a look
