help- my car shut off @ a red light and died
Old 04-30-2005, 04:21 PM
96MAXIMAGXE's Avatar
i just got home, my car ran fine all day today, but on my way home, i stopped at a red light and the car started shaking and just turned off, when i tried to turn it back on it wouldnt, so i`m stuck in the middle of the street and had to push it to the side, lucky some guy helped out. anyway i called a cousin and he gave me a boost right up. any ideas what this could be, i cleaned the throttle body about 2 weeks ago, and ever since then the car has been idling between 400-500 rpm`s, i have an auto so its supposed to be around 700-750rpm`s, whenever i stop at a light the car shakes, and when i hit the gas its fine, it`s just today it shut off, i cant have this car turning off like that i take a bridge to goto work, dont want it stalling out on the bridge, i searched and found someguy had something similar and it turned out to be the maf sensor? please help.
96MAXIMAGXE is offline
Old 04-30-2005, 04:33 PM
Mr.Duck's Avatar
check the maf sensor, and the coilpacks, has your SES light come on? you might want to check the codes for that, if you do get the codes, come back and let us know what they are so we can help your further
Mr.Duck is offline
Old 04-30-2005, 05:09 PM
i have had the check engine light, but its the knock sensor 0304, i cant do much right now because it`s dark and raining outside, but i did turn my car back on put it in drive, i turned on the radio, headlights, foglights, rear defrost, and all of the lights on the speedometer got very dim, and the car started idling at about 300rpm`s, i had all of these things on when the car first turned off, so i`m thinking bad battery or alternator?
Old 04-30-2005, 05:44 PM
after doing some more searching, i have found that people who`s alternator has been dying have symptoms of the car whining when they turn it on, that has been happening to me for about a month now. i didnt think much of it, i thought it was just one of the belts. i have a multimeter, how do i check the battery and alternator voltage?
Old 04-30-2005, 05:46 PM
1996blackmax's Avatar
You may also want check all your vacuum lines around the throttle body.
1996blackmax is offline
Lakersallday24
06-16-2019 01:35 AM
MaximaDrvr
08-19-2015 08:20 PM
doobadoo
08-15-2015 06:43 PM
Maxboy23
08-11-2015 11:59 AM
yat70458
08-03-2015 01:16 PM
Quick Reply: help- my car shut off @ a red light and died
