How to remove/replace oil pressure sending unit
Old 03-24-2005, 08:55 PM
jtm087's Avatar
How do youreplace your oil pressure sending unit?? No instructions in haynes manual
jtm087 is offline
Old 03-24-2005, 08:59 PM
southeast_first's Avatar
there are instructions in the stickies at the top of the forum. unplug the sensor, unscrew the sending unit, replace, reconnect. the hardest part is finding the oddly huge socket you need to uncrew the sending unit, i think it was 1 1/16" or something...
southeast_first is offline
Old 03-24-2005, 09:09 PM
jtm087's Avatar
i searched over and over and didnt see the post, and thanks for the info
jtm087 is offline
Old 03-24-2005, 09:14 PM
jtm087's Avatar
ohh yea, where is it?? pics??
jtm087 is offline
Old 03-24-2005, 09:16 PM
http://forums.maxima.org/showpost.ph...5&postcount=10
for lack of a better description, it's on the back of your oil pan, if i remember correctly. no pics, but out of curiosity: how do you know you need to replace it without knowing where it is?
Old 03-24-2005, 09:20 PM
jtm087's Avatar
I have a leak and one of the things they say in the haynes manual to check is the oil presuure sending unit, but dont supply pic or instructions on replacing it...thanks again!
jtm087 is offline
Old 03-24-2005, 09:33 PM
I30tMikeD's Avatar
It is very common to have a small bit of oil comming from the oil pressure sending unit on a higher mileage car, usually not a concern or enough to notice between oil changes. It is very easy to see, just jack up the passange side and take a look at the back of the oil pan. I
I30tMikeD is offline
Old 03-24-2005, 09:46 PM
beegeezy's Avatar
You should be able buy an oil pressure sending unit socket at any of the chain stores: autozone, pepboys, etc.
beegeezy is offline
Old 03-24-2005, 09:48 PM
jtm087's Avatar
good lookin on the info!!
jtm087 is offline
VQ'ed
Forced Induction
02-29-2016 08:05 AM
220k+ A32
18
09-22-2015 11:39 AM
JoshG
51
09-21-2015 10:41 PM
Quick Reply: How to remove/replace oil pressure sending unit
