-= Grinding Metal Noise... NEW PROBLEM =-
Old 02-23-2005, 01:53 PM
TheGAMEGUNIT05's Avatar
What up people, I was wondering if anyone else has this problem. Whenever I hit the gas hard, i hear a grinding of metal... or grinding of some sort. Im at 18K Miles. Anyone?
TheGAMEGUNIT05 is offline
Old 02-23-2005, 02:15 PM
install30's Avatar
Nope....not yet, hopefully never....
install30 is offline
Old 02-23-2005, 02:16 PM
jcberb's Avatar
Are you refering to your engine making the noise, or when your in motion, I had an issue with a grinding noise a couple of months ago. Apparently it had to do with some sort of a bent plate making contact with the rotors as i drove. Was caused by the Nissan Service dept when replacing my rotors.
jcberb is offline
Old 02-23-2005, 02:34 PM
hey, now that i think of it, my dealership has replaced my rotors two times now.. So It might be the problem like u said JCBERB, thanks for your info
Old 02-23-2005, 02:37 PM
jcberb's Avatar
Get it fixed as soon as you can, if it is the same issue i had, you run the risk of having veins engraved on your rotors.
Your welcome
jcberb is offline
Old 02-24-2005, 04:59 AM
TheOne01's Avatar
Yeah, actually I had my rotors replaced in November, and I am noticing the same thing........it's a metal grinding sound........you can notice it easier if you are up against a wall.........if the car is sitting parallel to something that the sound can bounce off of, you can easily notice it..........
TheOne01 is offline
Old 02-24-2005, 05:08 AM
phips25's Avatar
Well I curently have a metal rattleing sound and my dealership has diagnosed it as a bad strut, im going to be droping it off today to try and get fixed. Hopfull that will fix it, could this be the sound you here.
phips25 is offline
Old 02-25-2005, 08:44 AM
ethorn's Avatar
Just below 3000RPM?
Well atleast just below 3K RPM is where mine was. I was fearful it was something in the engine doing it. But My purchase dealer couldn't find the problem after having my car and giving me a loaner for a couple of days, This was about the only problem I had with the Dealer's service dept as EVERYTHING Else was great, Team Nissan Marietta.
I took it to Gwinnett Place Nissan after they moved to Pleasant Hill, and within 30 minutes came back to me and said they thought it was the exhaust. After about another 20 minutes they handed me a bracket for the exhaust (a frontal hard bracket) that the eye hole for the bolt was broken in half. They simply took it off as they can't get a replacement part anytime soon. The noise was gone.
ethorn is offline
Old 02-25-2005, 07:38 PM
jazz120's Avatar
i have a wierd gargling kinda noise(more like a running water actually) usually between 2 to 3 k rpm...doesnt matter if i am still or driving i have the noise coming directly from the glove compartment area. I went twice to see my dealer and both times they flushed my entire coolant system,checked the heater...but didnt solve the problem it is actually worst now...driving me crazy ..did anyone experienced it?
jazz120 is offline
Old 02-27-2005, 11:29 AM
Monotaur's Avatar
I've experienced the same (althoguh mine doesn't seem to be as persistant as yours...). There is a TSB for this (can't remebere where though - maybe someone else can point him to this?), and shold be performed ASAP as there is likely air trapped in the heater core. Although, you'd think a coolant fluch would maybe get rid of this?
Monotaur is offline
Old 02-27-2005, 12:26 PM
Jayzmax04's Avatar
I just had the gurgling problem fixed. It sounded like a waterfall rushing from front to back when I accelerated. They said it was air in my fluids. I had the 30k service done (I know, I know) and it stopped a couple days later.
But I STILL have the gringing noise up front. I have not had any work done to the rotors yet, so thats not it. OF COURSE, the dealer cannot hear the noise....Man I hate that. Seems there is always a noise of some sort, that only I CAN HEAR!!
Jayzmax04 is offline
Old 03-31-2010, 05:39 AM
jbolling's Avatar
2000 maxima:had front/back brakes replaced then the front rotors. Afterwards, a whining noise started and now there is a grinding noise when I make turns.
jbolling is offline
Old 03-31-2010, 07:07 AM
thealliance43's Avatar
probably your pass. mount. check it out right by ur winshield fluid
thealliance43 is offline
02PearlSE
02-01-2016 12:37 AM
Excalibur23
10-13-2015 04:33 PM
RWCreative
09-21-2015 11:01 AM
A32goldylocks
09-16-2015 01:33 PM
97_GXE
09-15-2015 06:47 AM
Quick Reply: -= Grinding Metal Noise... NEW PROBLEM =-
