how to get spray paint off your car ???
Old 04-21-2001, 08:52 AM
tunedup's Avatar
had a little accident with a spray paint car what would be the best way to possible remove this ...
thnx in advance.
tunedup is offline
Old 04-21-2001, 09:08 AM
Autobahn Max
Your not going to beleive this, but it actually works (I've done it myself after *%^$ing vandals spray painted my old car back in 1990). Go to the grocery store and get some "Lemon Extract Juice". I beleive McCormick brand sells it. It takes the paint right off and doesn't hurt your cars paint. A guy who used to work on typewriters tipped me in on this. He said it was the only way to get "white off" off of a typewriter without damaging the type writer itself. Good luck.
Old 04-21-2001, 09:17 AM
Minister of Silly Walks
mzmtg's Avatar
Clay bar?
mzmtg is offline
Old 04-21-2001, 09:33 AM
shane's Avatar
hi i have used wax/cleaner to remove small amounts of spray paint
shane is offline
Old 04-21-2001, 09:40 AM
My 4DSC
clay bar...
it will come right off...
Old 04-21-2001, 09:41 AM
Ramius83
A lot of elbow grease in my opinion. No, but what I would suggest trying is using "a tad" of nail polish remover, also depends what color your car is. Try it, give us the results.
Old 04-21-2001, 12:07 PM
teejnut's Avatar
clay bar works for sure
teejnut is offline
Old 03-02-2006, 02:34 AM
SHIFT_om nom nom nom
Metal Maxima's Avatar
I use bologna and soda
Metal Maxima is offline
Old 03-02-2006, 05:34 AM
Play with my balls
Deckdout2's Avatar
goof off strips the clear coat. do not use that.
Deckdout2 is offline
Old 03-02-2006, 08:36 AM
MidniteMaxSE's Avatar
EZ off oven cleaner!!!!
MidniteMaxSE is offline
Old 03-02-2006, 09:06 AM
UncleMax98's Avatar
Try claybar first. Other chemicals have the risk of causing damage to the clear coat.
UncleMax98 is offline
Old 03-02-2006, 09:14 AM
STFU n00b!
Matt93SE's Avatar
DO NOT use fingernail polish remover or oven cleaner!!! It WILL damage your paint.
to remove the overspray, you have several options.. if it's just the misty overspray crap, you can take it right off with a clay bar. If you actually 'painted' the car, you'll probably need to go to somethimg more aggressive, like rubbing or polishing compound and an electric buffer. That will take it right off, then you just need to re-wax that part of the car and you're done. will only take a few minutes.
If you got it on your glass (GLASS ONLY!!!), you can use a razorblade or some very fine steel wool and gently rub on the glass to remove it.
Matt93SE is offline
Old 03-02-2006, 01:51 PM
amimaxima
100 grit sandpaper
Old 03-02-2006, 03:07 PM
The Definitive AE Master
Larrio's Avatar
I used 3M rubbing compoud, came right off
Larrio is offline
Old 03-02-2006, 03:40 PM
VIP Maxima
larrio, any idea how to get caliper paint off leather seats?? just ONE drop
Lakersallday24
06-16-2019 01:35 AM
homewrecker
08-24-2015 08:56 PM
MAXSE5SPD
08-23-2015 12:06 PM
jchronis2552
08-13-2015 07:48 AM
Quick Reply: how to get spray paint off your car ???
