My car runs worse after cleaning EGR valve!?
Old 12-11-2004, 09:26 AM
Dabhar59's Avatar
Thanks for looking!
I recently replaced my spark plugs (with Nissan parts plugs) and also dismantled and cleaned my EGR valve, because my car failed the NO2 aircare testing, in my 92 Maxima V6 SOHC.
Now, however, I've noticed the idle acting strangely--when I slow down for a traffic light, the engine RPM's seems to drop very quickly into the idle, dipping to about 500rmps, then settling around 700rpm's. The engine sounds like it might stall, but doesn't. My gas mileage is noticable worse now as well.
Any ideas what this could be?
Much appreciated.
Dab
Dabhar59 is offline
Old 12-11-2004, 09:31 AM
blacks92seAuto
what did you use to clean it? and did you use a new gasket when installing?
Old 12-11-2004, 09:39 AM
Dabhar59's Avatar
TB cleaner.....
Used throttle body cleaner and replaced with new gaskets. But did notice that afterwards when I disconnected the vac hose, there was no change...the engine continued to run smoothly.
Dabhar59 is offline
Old 12-11-2004, 10:57 AM
Getting back to his roots
Mizeree_X's Avatar
Sounds like possibly the EGR is stuck open slightly. Rev the engine and feel the EGR move with your other hand. Try and see if it stays open after a few revs.
Mizeree_X is offline
Old 12-11-2004, 11:48 AM
Dabhar59's Avatar
oh oh
When I rev the engine, the EGR diaphram doesn't seem move at all, but when I push up on it, the engine acts like its going to stall.
Dabhar59 is offline
Old 12-11-2004, 12:59 PM
Mizeree_X's Avatar
Ok, it sounds like you have the same problem I did -- the vacuum source that opens and closes the EGR valve is bad. It could either be the EGRC solenoid, or the vacuum port itself. Also, if the EGR valve isn't opening at all, it shouldn't cause the idle problems you are having. I wish you good luck. Start checking any and all vacuum hoses for cracks or leaks. I don't own a VG so I can't get more specific than that, sorry.
Old 12-11-2004, 01:03 PM
Dabhar59's Avatar
Makes sense....
That makes sense....that the vacuum source is bad. I hope someone who knows what that is makes a posting.
Thanks for your help!
Dab
Dabhar59 is offline
Old 12-11-2004, 11:43 PM
alpicone's Avatar
Dab
Make sure you dont have the vaccum lines mixed up. The vaccum line leading to the EGR should not have any vaccum at idle. Check to make sure it doesnt. Also if you disconnect the vaccum line does the car idle better? The vaccum to the EGR only starts when you rev the engine.
alpicone is offline
Old 12-11-2004, 11:44 PM
alpicone's Avatar
If the EGR has vaccum at idle it will run like crap.
alpicone is offline
Old 04-25-2006, 05:24 AM
This ORG has saved me $$$$$$$$
Juicey's Avatar
HEY. Know this is an old thread but this seems similar to a problem I JUST got today while driving down the highway.
I came to a toll and as I slowed down the car started to chug and I thought it was going to cut out. This continued a tiny bit after I accelerated away. Once I got to about 65 though it did NOT happen anymore. It was only after I started to slow down again that the problem reoccured.
I haven't touched anything on the car. Could this be some bad vaccum line? How can I find out and is it simple to replace?
This is for a 93 max
Juicey is offline
Old 04-25-2006, 10:00 AM
Juicey's Avatar
bumpy-ity bump
Juicey is offline
Old 04-25-2006, 05:40 PM
RedDragon's Avatar
I had the same problem , it was the solenoid.
RedDragon is offline
Old 04-26-2006, 02:31 PM
kthxbye2u
xx-Marshall-xx's Avatar
you ever heard of *DO NOT CLEAN INTAKE MANIFOLD* ?... i tyhink some IM's say that but anyways
since you cleaned it with that stuff... the sensors are probably not registering the correct air / fuel crap... i know its the EGR and stuff but thats probably why its running bad... its the computer maybe
reason why im telling you this is because my friend did this to his and it ran bad it'll just take time and clean itself out of all the cleaner you used then it might run propely after that hope im right
xx-Marshall-xx is offline
kjlouis
11-24-2018 06:09 AM
Samedi
08-13-2015 04:05 PM
Balkins
08-12-2015 06:39 AM
acw
08-07-2015 04:20 PM
Quick Reply: My car runs worse after cleaning EGR valve!?
