Where is oxygen sensor bank 2 sensor 2?
Old 11-14-2004, 11:03 AM
hito's Avatar
I checked the ecu codes on my car with a CReader which threw out the codes:
From CReader Manual:
P0158 - O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 - 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
From Haynes Manual:
P0158 - Downstream oxygen sensor maximum voltage monitor fault
P0159 - Downstream oxygen sensor circuit slow response fault
So my question is... where is this sensor located, and how do you go about changing it? My max is a 99' and I hear that there were O2 changes on the car. If possible, DIY pictures for this how to would be appreciated.
hito is offline
Old 11-14-2004, 12:27 PM
I'm actually quite pleasant until I'm awake
killcrap's Avatar
sensor is in your b-pipe
killcrap is offline
Old 11-14-2004, 01:20 PM
larryseibel's Avatar
bank 2 sensor 2 is after the cat convertor in the b-pipe. also called the post cat or downstream oxygen sensor. bank 1 sensor one is the oxygen sensor in the y-pipe that cylider 1 is on. bank 2 sensor 1 is the oxygen sensor in the y-pipe where cylinder 2 is located.
larryseibel is offline
Old 11-14-2004, 02:47 PM
eng92's Avatar
If your 99 is cali-spec, you have four O2 sensors. There is a sensor before and after each of the two pre-cats. There is no O2 sensor after the main cat like the non-cali-spec 99s or the rest of the 95-98 fourth gens which have 3 sensors.
eng92 is offline
Old 11-16-2004, 04:36 AM
mkothari's Avatar
I have 99 California spec Max.
I recently got it replaced. It is a red wire cover on sensor harness.
I hope it helps. Send me an email at mkothari2@yahoo.com
and I have a pdf file that shows where it is. IT is from factory service manual.
I have it PDF form and I do not think I can attach here.
mkothari is offline
Old 11-16-2004, 04:40 AM
mkothari's Avatar
I have 99 California Spec Maxima.
I had replace rear left oxygen sensor a while ago (code P0158/P0159).
Now I got code P0138/P0139.
I ordered part from Walker generic sensor from oxygensensor.com.
But funny thing happened. I drove about 130 miles on highway and Service Engine Soon light went out. It has not come back yet.
Can anybody explain why this happened.
-Mahendra
mkothari is offline
jmlee44
10-02-2022 02:13 PM
my03maxima
04-29-2020 12:48 AM
hayne
10-05-2015 11:53 AM
Quick Reply: Where is oxygen sensor bank 2 sensor 2?
