what motor oil weight
Old 09-28-2000, 05:06 PM
Monil's Avatar
What motor oil weight should I use for my 1995 nissan maxima? Should I use 5w-30 or 10w-30? I live in PA and it is starting to cool down here. Thanks!
Monil
Monil is offline
Old 09-28-2000, 05:38 PM
Remington's Avatar
I'd say 5w30
That's what I use and I believe that is recommended in the owners manual.
Remington is offline
Old 09-28-2000, 05:49 PM
Albert's Avatar
you can use 10w30 during the warmer season.
stick with 5w30 for the winter. i'm using
10w30 now since that's what Costco have..6qt for $22.
but stay away from 10w40.
Albert is offline
Old 09-28-2000, 06:04 PM
Max96's Avatar
Stick with some good synthetic 5W30 year round.
Max96 is offline
Old 09-28-2000, 06:18 PM
compu_squid
Totally agreed
Mobil 1 5W30 ... you get what you pay for
~C
Old 10-04-2000, 08:41 PM
EZEMaxima's Avatar
10w40 oil
What is wrong with using a 10w40 oil in the Maxima?
EZEMaxima is offline
Old 10-05-2000, 12:31 PM
Superjzf
Oil
I use 5W30 as well. Mobile..
Old 10-05-2000, 01:00 PM
Bernie Lomax's Avatar
What's the difference
5w30 vs. 10w30 ?? Is 5w30 thicker? I see a lot of people using 5w30 around the board. Am I missing something? I just use Mobil 10w30.
Bernie Lomax is offline
Old 10-05-2000, 01:27 PM
dwapenyi's Avatar
Re: What's the difference
I'm with you Bernie
I think that thicker grades protect the engine better. The only reason I'd go with 5w is if I lived in Alaska. I think 5W may make the car a weeee bit faster, cause it's thinner. Small sacrifice I guess.
By the way, the service manual for a 98 Max says use 10W30 all the way down to 0 degrees celsius. Anything below, use 5W. The upper limits for both oils are the same though, i.e. use either for hotter temps to 100 and beyond.
dwapenyi is offline
Alexander's Avatar
5w30 vs 10w30
I'm no expert, but I seem to recall that 5w30 is recommended for winter driving and 10w30 is ok for summer driving - though I also heard that it's perfectly alright to use 5w30 all year round, it might just be a little more expensive.
Andrew Alexander
1998 GXE
Alexander is offline
Old 10-05-2000, 07:44 PM
sleeper's Avatar
oil
the manual says use 5w30 in winter for quicker starting,and when it is above 0 then to 10w30, the 2 will still won't go under thirty weight when the car is at operating temp.5w will have 5 at start, and 10w will have 10. i use 10w40, with the s/c since i like to race sometimes and the oil will be getting hotter,the 10w is the same as the 10w in 10w30 just the 40 will provide more protection at high temp., when racing around at the track. always let the car run for about at least 15 secs before takeoff.and take off before it get to operating temp. by the way i believe redline has a 0 ash content. they say spend now or spend more later. and another word about oil changes, 5k miles is a good standard to change oil. even though the oil is still good till about 8-10kmiles.(syn) i like to change mine every 2-3 k miles. new oil makes the s/c talk to me." i like that"wizzzzzzzzzzzzzzz. haha ,just trying to be funny again.
sleeper is offline
Old 10-06-2000, 10:01 AM
Synki's Avatar
Well, since i still work p/t at Jiffy Lube i deal with this everyday. What should be used is 5w30 for all temps. 10w30 can be used for the warmer seasons. The higher the number gets in oil (10w30, 10w40, 1540, 15w50, se30,etc) They get thicker. If you want the best, go with synthetic all the way. I use Mobil 1 5w30 since i've had my Maxima (now 26k miles.)
Synki is offline
Old 10-06-2000, 10:20 AM
I'm needing a caw
Jeff92se's Avatar
Viscosity weights-->
as the viscosity range increases ie.. 10-30 to 10-40 or 5-40 etc... the more viscosity modifiers the must have to be able to perform. ie.. 5w when cold and 40w when warm. As the oil ages(dino especially), it looses it's ability to perform like a 5w and a 40w(or whatever). Just one more reason to use synthetics. This types of oils don't require as much modifiers to perform adequately. Besides, who wants some dead dinosaur running though your engine anyway?? hehe
Jeff92se is offline
Old 12-08-2010, 08:35 AM
Blassmasta's Avatar
Alphanumerical designation of motor oil
Boys, stop talking out your backsides about THIRTY weight and FORTY weight oil. The first part of the name (5W, 10W etc.) is referring to the weight of the oil, the second part (30, 40, etc.) is referring to the temperature at which the oil will flow at. 30 weight oil is basically GEAR OIL and looks like frickin' molasses when you pour it.
Blassmasta is offline
Old 12-08-2010, 09:09 AM
eFLO's Avatar
5w is a thinner oil when cold so it flows than a 10w oil would thus providing better protection while the engine is warming up, when the oil warms up its all the same.....5w-30 10w-30 etc.
eFLO is offline
Old 12-08-2010, 09:17 AM
aackshun's Avatar
aackshun is offline
Old 12-08-2010, 09:56 AM
MakMax's Avatar
Royal Purple 5w-30
MakMax is offline
Old 12-08-2010, 10:01 AM
GGENIUS's Avatar
people who are actually worried about savin money between 5w-30 and 10w-30... go jump off a cliff.
GGENIUS is offline
Old 12-08-2010, 10:33 AM
pavelsmax's Avatar
Please don't attempt to get your post count up by bumping 10 year old threads.
pavelsmax is offline
Old 12-08-2010, 12:59 PM
SLOW
Nealoc187's Avatar
I've got a better idea. Don't bump threads from 10 years ago.
Nealoc187 is offline
litch
123
01-04-2024 07:01 PM
hcarter1112
42
07-18-2022 03:35 PM
AaronL
08-08-2020 10:31 AM
Unclejunebug
04-02-2016 05:42 AM
Quick Reply: what motor oil weight
