How to replace control arm bushings?
Old 10-30-2004, 12:49 PM
BluFlame's Avatar
I need help, i bought ES bushings from courtesy and i spent 3 hours today trying to remove old ones, i can't get stock bushings off? they look like they are glued on. I managed to take all of the bolts off but i cant seperate old bushings from the control arm. And new bushings seem too large, anybody know how to put them on? If anyone has done this give me some tips.
BluFlame is offline
Old 10-31-2004, 09:16 PM
kitmaxima's Avatar
i did it awhile back
i use a press to punch out the old bushings
or it was suggested me to burn it out
then use the press to put the new once
goodluck
kitmaxima is offline
Old 10-31-2004, 09:50 PM
Ant96GLE's Avatar
Yea you can burn them out but you'll definately need to get them pressed in...
Ant96GLE is offline
Old 10-31-2004, 10:54 PM
izzydig's Avatar
I burned out and drilled out old rubber on bushings, then used a hack saw to cut thru 1mm or less sleeves that hold the rubber in place. Used screwdriver to pry them out with minimal force.
Used a vice to push the new bushing setup back in.
izzydig is offline
Old 11-01-2004, 05:23 AM
Minister of Silly Walks
mzmtg's Avatar
The new ones DO NOT need to be pressed in. They slip right in with minimal effort.
mzmtg is offline
Old 11-01-2004, 07:01 PM
BluFlame's Avatar
It took me 4hrs to put the new one in, i could only replace one bushing (pivot). ES bushings were simply too big, i had to remove some material from them with dremel, i know it defeated the purpose of putting new ones in but i did this without removing the control arm from the car. Ride is ok so far, i feel aligment is off. I think GLE has a different bushing setup than other models.
My originals were torn off and i didnt feel like spending $200 on a whole assembly, this way i only spent $30.
BluFlame is offline
Matt93SE
05-24-2019 02:58 PM
maxocar
08-21-2015 12:57 AM
soon2ownmax
08-13-2015 02:19 PM
laparka66
08-06-2015 09:36 AM
00 Max
08-04-2015 07:09 PM
Quick Reply: How to replace control arm bushings?
