how much is reasonable for replacement of tie rods and ball joints?
Old 09-07-2004, 01:11 PM
michaelnyden's Avatar
how much should I expect to pay for replacement of the tie rods and ball joints....minus an alignment which I know I will need...??
I know the parts are super cheap, but the labor is rather large...I would guess
also, has anyone had their front strut bearings replaced....how much did that cost you at a shop??
michaelnyden is offline
Old 09-07-2004, 01:18 PM
I30tMikeD's Avatar
Your looking at alot of labor hours at a shop to relplace both ball joints, both tie rod ends and both strut bearings. I would say, just estimating, about 5-7 hrs of labor for all of that. The strut bearings are going to be the same labor as replacing the struts which is around 1.5 hrs a side.
I30tMikeD is offline
Old 09-07-2004, 01:21 PM
usmcbigguns's Avatar
what do these items cost? considering changing out these exact same items on my max.
usmcbigguns is offline
Old 09-07-2004, 01:55 PM
what is the easiest to do myself?
it looks like replacing the strut bearings is half the labor...I am going to wait on the strut bearings then and replace them when I replace my struts next.....is there any damage occuring from having bad strut bearings? in other words...is there a necessity to replace them soon?
the tie rods and ball joints I would think should cost me no more than $250? including parts and labor...
Old 09-07-2004, 02:15 PM
I30tMikeD's Avatar
Good luck getting both ball joints and tie rod ends done for $250 parts and labor. Labor will be that much at least. What is the labor rate at the shop you use? Most shops are around $60 hr labor.
Old 09-07-2004, 02:38 PM
Conecarver
BEJAY1's Avatar
I'd kill to find that rate. I just found out the Midas in Naperville is at like $84/hr. I'm gonna pull my own tie-rod end and control arm and do the work I need (assuming I can with jacks)
BEJAY1 is offline
Old 09-07-2004, 03:03 PM
the shop I take it to normally charges $40/hr....but he's my friends father, so he charges more along the line of $25/hr...and he doesn't mark up the parts at all...he gives me the prices that he gets....so he only makes labor on me...
Old 09-07-2004, 04:49 PM
I30tMikeD's Avatar
If you have a special hook up on parts and labor then why would you post a thread asking how much it costs?
Old 09-07-2004, 04:51 PM
I30tMikeD's Avatar
We charged $78 an hour which is a little on the higher side. But the Chicago land area has one of the higher automotive labor rates in the country.
Old 09-07-2004, 05:03 PM
well...I actually wanted to know the labor hours for a job like this...I phrased the question wrong...I shouldn't talked about it in dollars but rather labor hours...which you already answered....
Old 09-07-2004, 06:05 PM
tom_98se's Avatar
It also depends if you're replacing the whole control arm or just having a new ball joint pressed in. While the joint itself is like $30, a new control arm is around $200. I was charged two hours of labor to replace one control arm, if that helps.
Good luck,
TOM
tom_98se is offline
Old 09-07-2004, 07:38 PM
naw...I would just replace the ball joints...and tie rods...
I found a DIY write-up on here....hope it's not too hard...the DIY guide looks easy enough!
Old 09-07-2004, 07:40 PM
Sprint's Avatar
post the link.. i am interested
Sprint is offline
Old 09-07-2004, 09:01 PM
http://forums.maxima.org/showthread....ight=alignment
Old 09-09-2004, 09:10 AM
cyjad's Avatar
FYI about the balljoint 101 thread:
Those instructions are for a 94 max. I believe most, if not all, 4th gen max has the ball joint pressed into the control arm instead of the 3 bolts mentioned in the writeup.
This basically means that the control arm has to be removed whether you are replacing just the ball joint or the entire control arm.
cyjad is offline
Old 09-09-2004, 12:27 PM
Sprint's Avatar
damn that search function
Sprint is offline
kingw323
20
10-21-2015 08:36 AM
maxocar
08-21-2015 12:57 AM
jhontelj
08-17-2015 04:07 AM
soon2ownmax
08-13-2015 02:19 PM
classymax420
08-06-2015 06:35 PM
Quick Reply: how much is reasonable for replacement of tie rods and ball joints?
