Engine turns over, but won't start
Old 09-05-2004, 04:23 PM
high888's Avatar
Went out yesterday morning to start the car, and it turns over but will not
fire. Plenty of gas. Good battery, lights work, radio etc. Starter turns the
engine but that's it. Any ideas? 6 months old with 6,100 miles.
high888 is offline
Old 09-05-2004, 04:59 PM
CanadianMoFo's Avatar
Well a funny thing happened to me once. I blew a small fuse that controls if I recall correctly, the ignition control module.
Under the hood, there's a panel near the washer fluid container. Remove the little fasteners, and beneath is a fuse panel. It can be pulled out to gain access to the fuses and relays at the side. They are the mini type fuses that you can't see through to tell if they've blown or not. You'll likely need a circuit tester, or I bought a little mini-fuse tester specifically for them.
Go through them and likely its could be the 15A one on the ignition control module.
CM.
CanadianMoFo is offline
Old 09-05-2004, 05:56 PM
Max'D's Avatar
Heard that happing to a few Murano's, Armada It was something in the ignition switch..
Max'D is offline
Old 09-05-2004, 06:26 PM
04SEelite's Avatar
There is a TSB on this - check with your dealer...should be under warranty.
04SEelite is offline
Old 09-06-2004, 06:17 AM
PETZUK's Avatar
There is a TSB that covers no or hard starting when the outside temperature is cold. The fuel pump is the problem.
Mine did this and the new pump cured the problem.
However, this occurs under very cold conditions, which I don't think you have in Phoenix..... But, maybe the pump is causing your problem.
PETZUK is offline
Old 09-06-2004, 07:24 AM
high888's Avatar
I am towing it to Pinnacle Nissan Tuesday morning. We shall find out. And yes,
it was about 99 degrees here yesterday, so it was not a cold start.
high888 is offline
Old 09-06-2004, 10:52 AM
confident nissan owner
Nismotech1's Avatar
hey i work for a nissan dealer in fl and the only problem i have seen is a bad cam or crank position sensor, if this is the problem a dealer will find it in no time using conult.
Nismotech1 is offline
Old 02-13-2007, 07:59 AM
DRod's Avatar
Sorry to raise a thread from the dead, but I didn't want to be redundant.
Anyway, I was driving down the highway last night when I tried to pass someone...and my car didn't go any faster. I then tried the manual shift (I have a 5A) and it was stuck in 5th. So, I tried my best to keep the car alive all the way to the dealership. When I got there, we tried starting the car again. No dice.
Ended up it was the cam (crank) position sensor. They replaced both (had no idea there was a "both"). Under warranty, so it's all good.
DRod is offline
Old 02-13-2007, 11:06 AM
I Donate! Why Don't You?
xoomer.com's Avatar
What is it with these cars and cold temperatures. Don't nissan test their vehicles in sub-freezing conditions. For past two weeks (freezing temps on the east coast) everybody is having problems with HUs, starters, etc,etc, etc.
xoomer.com is offline
homewrecker
08-24-2015 08:56 PM
Justinmc760
08-23-2015 03:10 AM
beboski
08-16-2015 05:23 PM
BobMax
08-15-2015 12:35 PM
Quick Reply: Engine turns over, but won't start
