Is it okay to mix 10W-30 with 10W-40 oil ?
Old 03-28-2001, 09:52 AM
MAXDriver
What are the consequences of putting in 3 quarts of 10w-30 and 1 quart of 10W-40 at oil change ?
Old 03-28-2001, 10:11 AM
Daniel B. Martin's Avatar
Mixing viscosities is all right. However, Nissan prefers 5W-30. Cold-start engine noise has been attributed to thick oil.
Daniel B. Martin is offline
Old 03-28-2001, 12:15 PM
OzziSVT
100% corect, basically you would end up with a a viscocity of 10W-32.5, which is OK as long as your car can run in those parameters. But if a Maxima is supposed to run 5W-30, then do it or next time you take a corner at high revs you might drop oil pressure low enough to spin a bearing and f*** your engine. Don't screw around by putting in the wrong oil in order to save yourself $15. The consequences could be DISASTEROUS!
Old 03-29-2001, 11:52 AM
Alex9
Service manual lists 10w-30 and 10w-40 for temperature higher then 0 F and 20w-50 for over 50 F. So if you don't drive around the north pole - that's ok. And pressure with the thicker oil is always higher than with 5w-30, no matter what revs are. That's why 5w-50 and 15w-50 recomended for heavy duty driving.
Alex.
Old 03-29-2001, 01:54 PM
Engine oil viscosity
Originally posted by Alex9
Service manual lists 10w-30 and 10w-40 for temperature higher then 0 F and 20w-50 for over 50 F. ...
Which service manual? Not mine.
Old 03-29-2001, 03:48 PM
VQdriver's Avatar
Re: Engine oil viscosity
i just bought a whole box of mobil 1 synthetic 10W-30 motoroil..is 10W thicker than 5W? also, does this mean my gas mileage will suffer if i use this stuff for summer driving?
VQdriver is offline
Old 03-29-2001, 03:49 PM
Alex9
Sorry, it was user's manual for 95 maxima.
Old 03-29-2001, 03:51 PM
I'm needing a caw
Jeff92se's Avatar
It should be okay. But in the future, try to avoid 10w40 oils if they are dino type. It's a really big viscosity gap for the dino oil to maintain.
Jeff92se is offline
Old 03-29-2001, 04:03 PM
Re: Re: Engine oil viscosity
Originally posted by VQdriver
i just bought a whole box of mobil 1 synthetic 10W-30 motoroil..is 10W thicker than 5W? ...
Yes.
... does this mean my gas mileage will suffer if i use this stuff for summer driving?
Yes, but by only a small amount. Go ahead and use the oil you bought.
Old 03-29-2001, 06:00 PM
Synki's Avatar
10w30 and 10w40? I have always used 5w30 in my 92 and 99 maxima. When i used 10w30 in my 99, i lost about 20-30 miles per tank. My manual says to use 5w30 and when i worked at Jiffy Lube, all that was used was 5w30 as well. Just my 2 cents though.
Synki is offline
Old 03-30-2001, 04:07 AM
plrod Black 95 SE's Avatar
I live in FLA and when I use to use 10W30 or 10W40 would experience a little engine noise on cold starts. I now use 5W50 Castrol Syntech and no longer get that noise. Also make sure the filter you use has the valve in it to keep the oil from draining down into the pan. It looks like a spring inside the filter, and it's not on all oil filters which are sold for our cars.
plrod Black 95 SE is offline
Old 03-30-2001, 06:23 AM
JDwyer2821's Avatar
I am using 10w-50 fully synthetic.
JDwyer2821 is offline
litch
123
01-04-2024 07:01 PM
Miket2006
03-01-2021 03:55 AM
mclasser
22
11-12-2020 01:58 PM
05RLS2
04-14-2016 11:49 AM
Quick Reply: Is it okay to mix 10W-30 with 10W-40 oil ?
