What's the best way to connect two 4-gauge power wires?
Old 03-18-2004, 01:57 PM
CalsonicSE's Avatar
I had to reroute my main power wire, but unfortunately, the power wire is now too short. I know the ideal thing would to buy a longer power wire to replace the old one but I don't wanna waste $.
If I go out and buy few feet of wire, what's the best way to connect them to get a good connection? I'm mainly worried about an obstruction of the electrical current if I use regular crimp connectors.
CalsonicSE is offline
Old 03-18-2004, 03:21 PM
DrX
DrX's Avatar
You could use a 4ga inline fuse holder. I'm not sure if they make the same connector without the fuse, that would be ideal for your purposes.
DrX is offline
Old 03-19-2004, 05:09 AM
s0ber's Avatar
put 2 terminals on each end, put them together, put a screw and a nut on the other side and tightnen, wrap around w/ black tape...
Or. Solder them :P
OR! You could use a 4awg butt connecter and a little presser thing to crimp it... Personally I would just solder it I dont have patience to butt connect a wire that big, the 1st method would be effective too I think.
s0ber is offline
Old 03-19-2004, 12:54 PM
AscendantMax's Avatar
yeah, like someone suggested you can get a fuse 4 guage fuse holder and connect it like that. Or you can solder it.
AscendantMax is offline
Old 03-19-2004, 02:47 PM
friendhasmax's Avatar
you can technically solder it, but no way in hell is that a good solid joint...u need to have solder on the inside strands, nit just the outside, and if u tried to do that u would have one hell of a cold solder joint, and ****ty resistance,
friendhasmax is offline
Old 03-21-2004, 06:49 AM
§è~® f®ÈÄk
nismos14's Avatar
i would get a 4 gauge coupler, i have one in my car, and it works beautifully
nismos14 is offline
wyobbagy
01-03-2023 12:03 PM
The Frye
09-02-2021 11:03 AM
Quick Reply: What's the best way to connect two 4-gauge power wires?
