EVAP canister purge volume control valve??
Old 11-22-2003, 11:05 AM
JeEvE's Avatar
I got this code while trying to fix my Multiple Cylinder Misfire. Anyone know what this is? I have no clue what it does and where is located. Anything about this would be great. Thanks.
JeEvE is offline
Old 11-22-2003, 11:32 AM
Blazin......
bobjohnson's Avatar
search or see evap pics in sig_
bobjohnson is offline
Old 11-22-2003, 12:39 PM
JeEvE's Avatar
Thanks, thoses pics helped. Search doesnt work...
JeEvE is offline
Old 11-22-2003, 01:24 PM
Blazin......
bobjohnson's Avatar
im updatin that site now ,i have alot more info thatll be up later so try it again some time.
Old 11-23-2003, 07:28 PM
exardus's Avatar
hey jeeve, what fault code did you get, 0903? How did you fix it?
exardus is offline
Old 11-23-2003, 07:32 PM
...needs to please stop post whoring.
NickStam's Avatar
Evap canister may have seized. It's located somewhere underneath the driver's side rear tire. More underneath the trunk. It's near a black box.
I think
NickStam is offline
Old 11-24-2003, 03:22 PM
chiwchan's Avatar
I got code 10 08 and finally fixed it. Replaced the valve, make sure you order the correct part.Cost me about $140 to replace valve and mini hoses and bracket.
chiwchan is offline
Old 11-24-2003, 03:23 PM
chiwchan's Avatar
Alos, opened up the old damaged valve and the contacts were all corroded.
chiwchan is offline
Old 06-02-2004, 01:54 PM
slag's Avatar
Is this the part number for that valve?
149309E010
slag is offline
Old 06-04-2004, 04:30 AM
sterling99SEL's Avatar
Just after replacing my knock sensor, I'm getting these three EVAP-related codes:
P0446 - 0903
P1447 - 0111
P0440 - 0705
Is it likely I could have damaged my EVAP control valve or knocked a harness loose possibly?
sterling99SEL is offline
Old 06-04-2004, 05:12 AM
Guinader's Avatar
I have the same 1008 code, is it probably the same part needed to be replaced.
Guinader is offline
Old 06-04-2004, 01:35 PM
Supa Lao's Avatar
To fix my 0903 code. I just swapped out the valve. The valve is attached to the charcoal canister and is held on by 2 10mm bolts. I swapped that out and I haven't gotten any check engine light back.
Supa Lao is offline
Old 06-04-2004, 05:40 PM
now is this valve at the back of the car near the gas tank or under the hood? I was thinking the canister is in the back. Hope I replace the right thing.
Old 06-04-2004, 06:38 PM
G20Flyer's Avatar
When i got that code i went to the evap canister and noticed one of the wires was completely corroded through so there was no connection. I put new wires in the harness, hooked it back up and it works fine.
G20Flyer is offline
Old 06-04-2004, 08:24 PM
GarciaMaxima's Avatar
chiwchan
Where did you get the parts from? I got the same code. Where is the valve located?
GarciaMaxima is offline
Old 06-04-2004, 08:34 PM
chiwchan's Avatar
I purchase from Courtesy Nissan www.courtesyparts.com , I don't have the part numbers with me, but the part was redesigned, cost about $150 total. Will try to look up parts numbers Monday
Originally Posted by GarciaMaxima
chiwchan
chiwchan is offline
Old 06-05-2004, 05:26 AM
Supa Lao's Avatar
Canister is located on the drivers rear right behind the wheel.
Supa Lao is offline
Old 06-05-2004, 10:35 AM
maxima_million's Avatar
I've been getting 0705 and 0309 SES lights.... I thought for a while it was the charcoal canister, but after some readings, I'm thinking it may be the EVAP valve in the engine.... I went to the dealership and they were going to sell me the canister for about $50 and the valve switch for $35. Does this sound right? I'm not sure at this point... It's so much different than what I've been reading.
maxima_million is offline
Old 06-07-2004, 03:44 PM
chiwchan's Avatar
Parts I purchased for 10 08 (California Emissions):
14920 (Valve)
08911-1081G (Qty=2) - Bolts
14911E (Qty=2) - Clamp
14912MC (Hose)
14912MB (Hose)
Also need new bracket adapter
Call dealer to double check - can't find my invoice right now
chiwchan is offline
Old 04-18-2005, 11:55 AM
aleveran's Avatar
Where to buy (EVAP) Canister Purge Volume Control Solenoid Valve?
The dealer wants $ 251.00 for EVAP canister purge volume control valve.
I’ve noticed that people who had the same problem were able to get it for $140 -$150. Where?
What is the part number/numbers?
Appreciate your help in advance!
Best Regards, Alex
aleveran is offline
Old 04-27-2005, 03:19 PM
tuner001's Avatar
i just had the same 0903 and 0705 codes pop up and was searching for some info on what to do you guys rock
tuner001 is offline
Old 10-30-2006, 02:18 PM
ben805's Avatar
My 96 GXE got the code 1008, should I replace the valve? why is this darn thing cost so much and where can I get it cheaper?
ben805 is offline
Old 11-01-2006, 02:16 PM
sagres74's Avatar
Recommend taking the valve apart and try to fix it yourself, especially if it's a matter of wire/contact corrosion or bad spring - there is another discussion about the topic. Recommendation from that discussionwas to replace the spring. I'll try anything once to save $100-$150.
sagres74 is offline
Old 11-02-2006, 12:43 PM
ben805's Avatar
Ok, I took the valve apart and everything looks good, spring and internal parts are in excellent condition, contacts have absolutely no corrosion or anything. Put everything back together with the connector hooked up, ignition on, blow through the nipple thing and the valve was closed, no air getting through, with ignition off I can blow through it, so the valve is function properly I assume. But after driving for couple miles the CHECK engine light came back with the same code 1008.....WTF? check harnesses and they're good, no blown fuse either....please help!!
ben805 is offline
Old 11-02-2006, 01:45 PM
ShRapNeR's Avatar
i also have 10 08.. dealer gave me the part for the rear of the car (this the right one?) and the light stayed on. after i reset ecu..
or the 10 08 the valve under the hood. if so exactly where?
ShRapNeR is offline
Old 11-12-2006, 11:25 AM
ben805's Avatar
I bought the ECPVCV from local nissan dealer for $195 and had it replaced last week, the 1008 (P1445) code never came back.....yay!
ben805 is offline
Old 04-15-2007, 04:10 PM
e_racer1999's Avatar
sorry to bring back an old thread (although it seems to have been revived MULTIPLE times....
but is there a link to said discussion? i've been having this code on my infiniti i30 for a while and have been trying to figure out a cheap way to fix this blasted PVCV
e_racer1999 is offline
Old 04-20-2007, 11:02 AM
anyone wanna respond?
Old 05-23-2007, 06:17 PM
oTranscendental's Avatar
BUMP for P1447... evap purge flow monitor
Anyone have pics of the valves in the engine bay? The link above is DEAD... anyone have an update?
oTranscendental is offline
Old 05-24-2007, 11:26 AM
Bump........
Old 05-24-2007, 11:29 AM
95turbo gxe's Avatar
what does the evap control Do?
95turbo gxe is offline
Old 06-23-2007, 01:29 PM
jpaul2's Avatar
Do you still remember what you replaced for the code 1008
jpaul2 is offline
Old 06-23-2007, 01:30 PM
jpaul2's Avatar
And where is is located
jpaul2 is offline
Old 06-23-2007, 03:27 PM
willard00's Avatar
evap vent control valve, its located on the charcoal canistor in the rear of the vehicle (opposite side mufflers on). takes about 5 mins to install.
willard00 is offline
Old 06-23-2007, 05:21 PM
mansurxk's Avatar
This vent control valve can throw an 1008 code?
i swapped the purge control valve, purge volume control valve after getting a 1008. gas cap is fine. still getting code so i should look towards the vent control valve?
mansurxk is offline
Old 06-23-2007, 05:29 PM
willard00's Avatar
it solved my problem. was $120 from the dealer (called a few different ones and prices varied by like $10-20 though)
Old 06-23-2007, 06:15 PM
mansurxk's Avatar
i'll check it out tomorrow. so i just watn to confirm your max was throwing an 1008 as well?
mansurxk is offline
Old 08-11-2007, 03:52 PM
shell's Avatar
EVAP Canister Purge Volume Control Valve disassembly
so I got the 1008 code on my inspection. I followed the Nissan manual's instructions for troubleshooting. Checking the EVAP CPVCV,
One is supposed to see ~31 ohms betwen the center and the left & right connectors of the valve. That is,
one's supposed to see 31 ohms between contacts on 2&3, 2&1, 5 &6, 5&4.
There was no contact (inf. ohms) between 2 & 1, and since I read that the valve is basically just a stepper motor, I decided to take it apart to see if it was just a loose solder joint or something I could fix myself.
here's the valve:
and again:
Taking off three screws on the plastic end reveals the motor insides:
(continued in next post)
shell is offline
Old 08-11-2007, 03:58 PM
shell's Avatar
EVAP Canister purge Volume Control Valve disassembly
(continued)
I then took the solenoid assembly (the stacked thing on the plastic part) apart, to see if I could fiddle with the contact enough to fix it:
Unfortunately, no amount of fiddling fixed that contact. I soldered the solenoids back on, put the thing together, and installed it back into the car. I still don't want to pay $180 for it, so I'll try finding one of these things on a junkyard to get a working solenoid out of. Stay tuned.
shell is offline
Old 08-16-2007, 05:37 PM
jteer1971's Avatar
Is that the purge volume control valve?
My dealer has diagnosed that as my problem but wants to charge 2 hours labor plus parts to change it.
jteer1971 is offline
Quick Reply: EVAP canister purge volume control valve??
