How to change manual transmission fluid? Which fluid: GL-4 or GL-5? Best gear oil?
Old 06-18-2003, 03:44 PM
stan's Avatar
transmission fluid
does anybody have a link where i can go to find out exactly how to change transmission fluid. 95 maxima 5spd
also, any opinions on lucas gear oil.
How to change the manual transmission gear oil on all 5-speed 1992 to 1994 VE30DE Maximas:
Here's the official FSM printout of how to do this:
It is very similar to the procedure outlined below for the 5-speed 1995 to 2001 Maximas, so it's recommended you review that procedure as well. The main thing to get out of the above picture is the gear oil capacity and the torque ratings for the drain and fill plugs.
How to change the manual transmission gear oil on all 5-speed 95 to 2001 Maximas:
2 excellent write-ups:
http://vbxmaxima.8m.com/mtoil.html
http://maxima.cardomain.com/member_p...=200625&page=7
How to change the manual transmission gear oil on all 6-speed 2002 and up Maximas:
http://www.greghome.com/Greg's%20Gar...axSE/MT-90.htm
Recommended Gear Oils include:
Amsoil 75W/90 Gear Oil: http://www.amsoil.com/storefront/mtg.aspx
Redline MT-90
Mobil 1 75W/90 Synthetic Gear Oil
Redline MTL (for extreme Northern climates, Canada area, etc.)
Please only use a GL-4 gear oil.
It is recommended that you change your gear oil at least every 60k, although Nissan doesn't explicity give an interval on manual transmission fluid. More info can be found here:
http://forums.maxima.org/oldthread.p...hreadid=225505
It is highly recommended you have your gear oil analyzed, as this is often neglected much to the peril of expected transmission life.
stan is offline
Old 06-19-2003, 03:51 PM
vicodin ... gift of life
nadir_s's Avatar
How bad is GL-5 for our transmission??
well... i'm not sure, but I will check w/ the shop, but I think they put in GL-5 fluid and my shifting is really knotchy and hard to get into gear. This was after they replaced 3rd, 4th gear, and a couple synchros.
I have about 140 miles on the transmission so far and I'm planning to dump that oil and refill w/ GL-4 once I hit the 1k mi. mark on the tranny.
Well, is it ok for me to run the car for a thousand miles on GL-5?
nadir_s is offline
Old 06-19-2003, 06:20 PM
iwannabmw's Avatar
Re: How bad is GL-5 for our transmission??
I would drain it immediately. The EP additives in a GL5 lube can literally eat the softer metals found in a tranny specced for a GL4 performance level. If you like your new synchros, get it put of there ASAP.
iwannabmw is offline
Old 06-19-2003, 06:27 PM
SterlingMistMax's Avatar
Its not good for your tranny GL-4 only i think it ruins the synchros
get some Redline MT-90
SterlingMistMax is offline
Old 06-19-2003, 08:11 PM
'Trynna' is not a word
mtrai760's Avatar
GL-5 contains friction modifiers that will eat away at your trannies gears and sycros, change the fluid asap.
mtrai760 is offline
Old 06-20-2003, 12:33 AM
nadir_s's Avatar
*******, now im scared!
well, is there a specific weight for the fluid i should follow? Also, does Autozone or Pepboys usually carry em? or should I go to my dealership
nadir_s is offline
Old 06-20-2003, 03:06 AM
your gonna find it very hard to find anything that is GL-4 when i looked nobody had it so i ordered Redline Mt 90 from A&A auto parts
Old 06-20-2003, 09:20 AM
nadir_s's Avatar
I want redline mt-90 in there but i'd like to flush out any metal shavings that occur while breaking into the tranny.
I guess i'll contact my local dealership and see if they have it.
nadir_s is offline
Old 06-20-2003, 11:28 AM
2kseman's Avatar
Don't use Lucas Gear Oil. Use Amsoil Series 2000 gear oil or Redline MT-90 gear oil. You can get the Amsoil gear oil by PM'ing member iwannabmw.
Just picked a 24oz bottle of Lucas transmission fluid......then saw this post.....how's Redline 90 better? I don't know much about the two, thanks.
2kseman is offline
Old 06-20-2003, 01:48 PM
stan's Avatar
what about lucas oil for the crankcase. is there something better for that also.
stan is offline
Old 06-20-2003, 02:08 PM
Evil Administrator - "The Problem"
bill99gxe's Avatar
Please don't use oil additives. Spend your money on good quality oils (Amsoil, Mobil, etc) in the first place, which negates the need for oil additives.
bill99gxe is offline
Old 06-20-2003, 07:18 PM
2kseman's Avatar
thanks for the link........
2kseman is offline
Old 07-02-2003, 09:16 AM
Getting back to his roots
Mizeree_X's Avatar
Changing the manual tranny fluid on my 92 SE
I have a couple questions about changing the gear oil on my 92SE. Looking at the FSM, the picture depicting the filler plug is vague at best. I got under the car and checked it out, but there doesn't seem to be a clear choice for the drain plug. Can someone describe its location for me, or take a picture? The other question is that, not having dealt with high weight lubricants before (75W+), I was wondering if the old fluid is going to come out easily, or if I have to get it really hot and then drain it immediately. Will I need an extra qt of new fluid to "push" any remaining fluid from the casing? Thanks for any advice.
Mizeree_X is offline
Old 07-02-2003, 10:08 AM
I'm needing a caw
Jeff92se's Avatar
My sticky post w/ the chilton's online.
Jeff92se is offline
Old 07-02-2003, 12:52 PM
Mizeree_X's Avatar
I own a Chilton's and a FSM. Both use the same vague illustration I have scanned and attached below:
I was just wondering if someone who has done this already can clarify which bolt that is, since there are half a dozen in that general area.
Old 07-02-2003, 01:26 PM
I'm needing a caw
Jeff92se's Avatar
Those pictures are correct. Once you get down there, you will see it. The fill plug is the only one that looks like that. It's fits a 1/2" drive wrench
Jeff92se is offline
Old 07-11-2003, 09:18 AM
Mizeree_X's Avatar
I replaced the tranny oil yesterday. Car has 76k miles on it, no idea when the fluid was last replaced. I drained and refilled, then got a chance to see the old fluid. It was black, and poured like motor oil! The new stuff, on the other hand, was golden yellow and poured like honey. I am very glad I changed the fluid. The gears shift noticeably smoother now. Thanks for the tip Jeff.
Old 08-22-2003, 10:44 PM
Boznian's Avatar
Cheap price of Redline tranny fluid,
www.myoilshop.com
It is $7.00 for a quart. For 10% discount, at check out, type in: 675421
Buy 5 qt of MT90 - it's a GL 4 grade!!
Boznian is offline
Old 10-22-2003, 09:31 AM
ablythe's Avatar
I have an '02 with the 6-speed. What is recommended here? What is the procedure?
ablythe is offline
Old 10-27-2003, 12:14 PM
bill99gxe's Avatar
Please go to the first post and find the section titled: "How to change the manual transmission gear oil on all 6-speed 2002 and up Maximas"
Old 04-24-2004, 06:29 PM
swiora's Avatar
Thanks for the links and info, but I have a question. You state Mobil 1 75W90 is a recommended gear oil, but you also state do not use GL-5 oil, only GL-4. Mobil 1 is GL-5, and I'm confused.
swiora is offline
Old 04-25-2004, 11:53 AM
lubricity's Avatar
Gl4/gl5
Well this quote is kinda funny" The EP additives in a GL5 lube can literally eat the softer metals found in a tranny specced for a GL4 performance level. If you like your new synchros, get it put of there ASAP." The additive package is IDENTICAL. Just that the viscosity is thicker in 5.
lubricity is offline
Old 07-23-2004, 11:45 PM
Hooooooonda.....
DAVE Sz's Avatar
The FSM says to use GL4 with viscosity 80w-90 ONLY. Is 75-90 ok cause it's synthetic? It also states that for the non LSD tranny to use 9.5-10.125 pt, meaning 4.75-5.062 quarts. The lsd model uses a bit less cause I'm guesing the lsd unit takes up more space.
DAVE Sz is offline
Old 08-01-2004, 12:09 AM
RyanTaylorClark's Avatar
My Chilton book said to make sure to use gear oil rated at GL-4, but couldn't really find any around town. I finally just asked the guys at Autozone if the Mobil1 75W-90 GL-5 would be ok to use, or if it would cause problems in my car. They said it would be fine. While the tranny oil was draining, I looked at a few sites like this one and realized that it might be a bad idea to put the oil I had just bought into my car. I called the local Nissan dealer and spoke to a guy in the service department and he also said it should be fine. The GL-5 hasn't even been in my car for 2 weeks, so I wanna know if you all think I should get that outta my car, or if it will be ok to leave in there for a few years. I am hearing contradicting stories, so will someone give me a good solid answer and not just opinion to answer this question for all us MT owners once and for all. As with all of us on this site, my Max is my baby and I would hate to do anything that would harm her. A response ASAP would be very much appreciated.
RyanTaylorClark is offline
Old 08-21-2004, 07:39 PM
VeeQueue's Avatar
I've used Redline MT-90 and Amsoil Series 2000 Synthetic 75W-90 Gear Lube and the Amsoil is superior to Redline MT-90 in all weather conditions. I live in Southern California and it can get well over 100 degrees in the summertime to 15-20 degrees in the mountains during wintertime. With Redline in my gearbox, there is an improvement vs. factory fill gear lube however on cold mornings it can still be very notchy/difficult to shift. Sometimes it may take 5-10 minutes of driving to eliminate the notchiness.
With Amsoil the shifter slips into any gear ALL THE TIME. I can shift into first gear in cold mornings above 15mph w/ ease. In fact w/ my B&M short shifter and Amsoil the gearbox shifts smoother than Redline w/ the stock shifter in all climates. I still have one unopened bottle of Redline MT-90 sitting in my storage room collecting dust and cobweb.
VeeQueue is offline
Old 08-21-2004, 07:57 PM
VeeQueue's Avatar
The additives in GL-5 will eat away all the yellow metals in the tranny, such as the syncros. Sadly you cant rely on Nissan dealers. This dealer mechanic was adding LSD addititve to the gearbox of a 95-96 Maxima. I asked him "why?". He told me all SE models came with LSD standard . Sadly GL-4 isn't readily available but the aftermarket synthetic gear lube available are much better than the factory fill and 100000000000000x better than any GL-5 because the GL-5 is not formulated for our transmissions.
VeeQueue is offline
Old 08-22-2004, 08:48 PM
Hooooooonda.....
DAVE Sz's Avatar
NAPA has GL-4, not sure if its a GOOD product.
DAVE Sz is offline
Old 08-25-2004, 02:40 PM
MAX2000JP's Avatar
I put in Coastal GL3, GL4, GL5 oil from Pep Boys. Is this alright for my tranny?
MAX2000JP is offline
Old 08-27-2004, 01:44 PM
Hooooooonda.....
DAVE Sz's Avatar
No, there's like 10 posts that say to use only gl-4 in the trans and none of the blends.
Another thing, is the pennzoil 80w90 GL4 any good? I really don't need or want synthetic.
DAVE Sz is offline
Old 08-28-2004, 11:53 AM
MAX2000JP's Avatar
Thanks, do you know anyone that sells GL4 locally. I tried NAPA, AutoZone, and Pep Boys and they dont have it.
Old 08-28-2004, 09:13 PM
Hooooooonda.....
DAVE Sz's Avatar
There's a place around belmont/harlem that seems to sell a lot of stuff others don't carry. They have pennzoil GL-4 but I'm not sure how good it is. Either way it's not synthetic, I don't think it is, but I'm getting it anyway.
http://www.pennzoil.com/products/gea...lus8090g4.html
What's the difference between this one, AMSOIL Synthetic SAE 80W-90 Gear Lube, GL-4, MT-1 and this one AMSOIL Series 2000 Synthetic Racing Gear Lubes SAE 75W-90 Synthetic Gear Lube, except the price of course?
DAVE Sz is offline
Old 09-21-2004, 03:20 AM
panda_1's Avatar
what about the gm syncromesh fluid, ive been reading online about it and everyone is swearing by it, any orgers use it?
panda_1 is offline
Old 10-15-2004, 09:41 PM
EyesOnly's Avatar
I own a 3000GT VR-4 (6-speed), and absolutely EVERYONE in the 3000GT community swears by it, and we have the absolute worst transmissions in relative terms of breakdowns. I had it put in when I had my tranny rebuilt, but since I had all the synchros replaced, I don't know which is attributable to the synchromesh fluid.
I'd be interested to know the answer to this question- we need to change my GF's '97 SE tranny fluid in a bit, and I had heard that synchromesh works in all manual trannys. We had it done at the shop only like 15k ago, so I'm getting stressed that they put in GL-5 by accident... Any way for me to find out? I'll have 'em rebuild that tranny, too, if they did...
Jason
EyesOnly is offline
Old 10-19-2004, 11:14 PM
haysdb's Avatar
According to talkinghorse, Amsoil TGR Series 2000 75W90 is no longer available.
I tried to place your order for the gear oil this morning, but I ran into a problem. AMSOIL has introduced a new gear oil called Severe Gear and it is a replacement for the Series 2000 product you requested. The problem is that the new oil is GL-5 rated, not GL-2 thru GL-5 as was the Series 2000 oil. Nissan recommends GL-4 for your car.
As an alternative, I can also try to order you the 80-90 GL-4 lower unit gear oil (product Code ALU)...I think that product is still available and it costs about half as much as the Series 2000 oil you wanted.
Unable to get the Amsoil Series 2000, I ordered Redline MT-90 from www.myoilshop.com. The cost for 5 qts, with shipping, was something like $37.50. I used the "dealer code" 675421 for 10% off the normal $7.00 per qt price.
haysdb is offline
Old 10-27-2004, 09:21 PM
HitmanAngel2k3's Avatar
will 5 qt of MT-90 be enough for 2k1 AE?
HitmanAngel2k3 is offline
Old 10-29-2004, 10:44 PM
Hooooooonda.....
DAVE Sz's Avatar
Yes, since you have the lsd you only need 4.25 quarts instead of 4.75 or so.
DAVE Sz is offline
Old 11-01-2004, 05:57 PM
haysdb's Avatar
My first attempt at changing manual transaxle gear oil isn't going very well. I rounded off the drain plug trying to remove it. I used a 12mm flare wrench and STILL rounded the darn thing off. Once I obtain a replacement I will try to remove the old one with Vice Grips or something.
Plan B was to remove this plug...
...which of course I broke when putting the bolt back in. I was just trying to get the bolt "snug" when I heard the crack. Obviously this bolt doesn't tolerate much more than hand tight. So, now I get to make a trip out to the Nissan dealer for a replacement.
Nissan sure as heck put the drain plug in an awkward spot. It's especially funny that they specify a torque value for tightening the drain plug, although how one would get a torque wrench on it is anybody's guess.
Oh, and the Haynes Repair Manual was a big help:
Remove the drain plug at the bottom of the transaxle and drain the fluid.
No picture, and no advice as to exactly HOW one is supposed to remove that plug.
haysdb is offline
Old 11-01-2004, 06:01 PM
I'm needing a caw
Jeff92se's Avatar
Well lucky that part should be only $20 or so. Bad thing is you have to drain all the fluid out again to replace it. Might was well pick up a new drain plug.
When I replaced that sensor, I had to put in the white toggle piece by brail. haha. then put the sensor itself in. But I had to move it around to get it to seat. Try to shove it in as much as possible before tightening that one bolt that holds it on
Jeff92se is offline
Old 11-01-2004, 06:10 PM
haysdb's Avatar
White toggle piece?
One other thing. Tracing the sensor wire up into the engine compartment, I found the connector OK, but there is no way I will be able to route the new wire back the same way as it currently is. That's not really a big issue, I just think it's interesting how that wire is routed.
haysdb is offline
Old 11-01-2004, 06:11 PM
I'm needing a caw
Jeff92se's Avatar
When you buy the new piece you will know. The harness just loops over the tranny into the connector. Should be easy.
Jeff92se is offline
Quick Reply: How to change manual transmission fluid? Which fluid: GL-4 or GL-5? Best gear oil?
