Empty Cd Won't Eject
Old 06-04-2003, 09:59 PM
eyal8r's Avatar
Cd #3 on the Bose Changer in my 2k3 Max SE is stuck. There is no cd in there, but the deck thinks there is- but it won't eject bc it thinks there's nothing there. And it won't allow me to load one either bc it thinks there's one in there already. How do I fix this?
D
eyal8r is offline
Old 06-04-2003, 10:01 PM
guapsnaman's Avatar
I guess you gotta go to a dealer. If not, try a Bose repair man. Then again, I don't have a Bose system because I am too poor to afford one. Maybe someone else can help you more.
guapsnaman is offline
Old 06-04-2003, 10:03 PM
eyal8r's Avatar
Damn- that sucks... anyone else have any ideas on how to fix this?
Thanks!
D
eyal8r is offline
Old 06-04-2003, 11:32 PM
saxdogg's Avatar
Dealer replacement. Do you really want this junk one fixed? Get a new one! (or get in line for a new one )
ARFF
saxdogg is offline
Old 06-05-2003, 06:41 AM
eyal8r's Avatar
How do I DEMAND a new one over getting it fixed?
THANKS!
D
eyal8r is offline
Old 06-05-2003, 06:46 AM
NT2SHBBY
believe you me, be glad u didnt get it...I bought it thinking it'd be as awesome as it was in 02 altima...what a piece of **** it is....it's low, real sh!tty treble and overpowering muddy bass....
to compound the heartache, it's a b!tch and a half to upgrade, basically the system should be replaced in it's entirety.....
Old 06-05-2003, 07:03 AM
naerok's Avatar
This happened to my friend. He went to dealer and got a whole new deck....
naerok is offline
Old 06-05-2003, 08:47 AM
ajahearn's Avatar
I would go get a replacement deck. But have you tried having the CD player eject all (hold down the eject button). This may be different than simply ejecting 3. Hope this helps.
ajahearn is offline
Old 06-05-2003, 08:55 AM
t56gen3's Avatar
I doubt they replace the decks with new ones, most manufacturers don't. Usually they swap it out for a refurb one that has been repaired. You really don't have much choice though--get it replaced or go aftermarket. If it's acting up now it will only get worse over time. I would try the "eject all" thing first, and if that doesn't work then pull the deck and disconnect the harness for 30 minutes or so to reset it.
t56gen3 is offline
Old 06-05-2003, 02:25 PM
eyal8r's Avatar
ok- Ill try those things! AWESOME!! THANK YOU!!
D
eyal8r is offline
Old 06-05-2003, 03:02 PM
BiggD23
You mean 31 doesn't overpower you?
Old 06-08-2003, 08:34 PM
eyal8r's Avatar
ok- I did the eject all function- and guess what? It ejected them all, but now it won't let me put any new cd's back in! What a POS!!! Any suggestions (other than taking the damn thing back?)
D
eyal8r is offline
Old 06-09-2003, 05:52 AM
t56gen3's Avatar
D
Pull power on it for 30 minutes or so, maybe it will reset. Odds are it will happen again though. Might go ahead and let the dealer fix it now.
t56gen3 is offline
Old 06-09-2003, 08:44 AM
T-bone's Avatar
yup,
I had a problem with a 12 disc JVC that would not eject the magazine. To solve this, I had to unplug it's power source thereby reseting it. When I plugged it back in, the magazine ejected.
T-bone is offline
Old 06-09-2003, 09:09 AM
eyal8r's Avatar
so just disconnect the battery in the car for an hour and this will fix it?
eyal8r is offline
Old 06-09-2003, 09:21 AM
T-bone's Avatar
NO, there should be a power source for the cd player; unplug that.
T-bone is offline
hez8813
09-27-2015 08:37 AM
DarjeelingRose
09-15-2015 01:20 AM
markevans999
09-10-2015 04:29 PM
Courtneysnow
09-04-2015 05:10 PM
Quick Reply: Empty Cd Won't Eject
