Intake air temp sensor location?
Old 04-11-2003, 04:58 PM
Maximam's Avatar
Does it matter if the sensor is located in the stock cold air funnel when using a Frankencar intake? Car runs very strong, seems fine. On the stock box the IATS is located well before the MAF. On the Franken, it is located just after the MAF, seems I may be getting a better reading having it located in the stock location and is where it is located.
Maximam is offline
Old 04-11-2003, 05:48 PM
IMBOUTTOBUSTSOMEGHOSTS
sloppymax's Avatar
Re: Intake air temp sensor location?
i have been pondering the same thing. i was going to plug up my midpipe and run the sensor in its original location to see if i could notice any difference. the only scenario i can think of that would make cause it not to matter as if that sensor is passive. perhaps its just monitors the temp but does not change anything. on the other hand, if it senses hot temps, then it may send a signal and retard timing to avoid knocking. does anyone have any conclusive info as to whether the air temp sensor has any affect or is it just way to monitor a function.
sloppymax is offline
Old 04-11-2003, 06:27 PM
Loe max's Avatar
You can stick it on to of the battery and nothing will go wrong. Just make sure you plug up the hole though. The sound is too high pitched and it doesn't growl the same way as a pluged up one.
Loe max is offline
Old 04-11-2003, 06:41 PM
MajesticBlueNTO's Avatar
i left mine in the stock location ..i asked FrankenCar if they could make a midpipe without the ATS hole. runs great, growls nicely
MajesticBlueNTO is offline
Old 04-11-2003, 06:44 PM
Maximam's Avatar
Ya I have to tape the hole on mine. Car runs great so I guess it to be fine.
Maximam is offline
Old 04-11-2003, 07:05 PM
sloppymax's Avatar
i would definately plug it, no one needs any unfiltered air coming for long periods of time. does anyone have a fsm that might shed some light on whether the sensor controls any settings?
Old 04-11-2003, 07:16 PM
Got Bent?
UMD_MaxSE's Avatar
From the FSM:
The intake air temperature sensor is mounted to the air duct housing. The sensor detects intake air temperature and transmits a signal to the ECM. The temperature sensing unit uses a thermistor which is sensitive to the change in temperature. Electrical resistance of the thermistor decreases in response to the temperature rise.
On Board Diagnosis Logic
Malfunction is detected when
(Malfunction A) an excessively low or high voltage from the sensor is sent to ECM,
(Malfunction B) rationally incorrect voltage from the sensor is sent to ECM, compared with the voltage signal from engine coolant temperature sensor.
UMD_MaxSE is offline
Old 04-11-2003, 07:23 PM
sloppymax's Avatar
Originally posted by UMD_MaxSE
From the FSM:
thanks alot for the info. ill hopefully have some software son for my laptop so i can run tests on intake temps. i just want to see how much of a difference it will make in either location.
Old 04-11-2003, 07:25 PM
Maximam's Avatar
From the FSM:
So based off this would you keep the sensor in it's stock location when used with a Frankencar or would you put it in the Franken location of after the MAF?
I left it in the stock location as that is as close to stock location as possible (before the MAF getting cooler air).
Maximam is offline
Old 04-12-2003, 10:37 AM
Got Bent?
UMD_MaxSE's Avatar
I would say it doesn't really matter. But if you have it in the stock location it is fine... I have mine in the midpipe after the MAF and it's fine
95Maxi
35
09-02-2015 10:37 AM
95Maxi
08-29-2015 09:38 PM
bc992164
08-26-2015 12:19 PM
MaximaDrvr
08-19-2015 08:20 PM
Quick Reply: Intake air temp sensor location?
