Lift points on the car?
Old 04-10-2003, 12:11 PM
Str8ridin's Avatar
What are all the proper places I can place a jack under the car to properly lift the max (front and back)?
-str8
Str8ridin is offline
Old 04-10-2003, 12:21 PM
When I put Max up on the lift I use the jack points stated in the owners manual.
You can jack the whole front end up by the support beam under the engine.
If you don't have a sway bar, you can use the rear beam to raise a rear wheel off the ground quickly without jacking the whole car up.
Old 04-10-2003, 12:24 PM
Str8ridin's Avatar
Thanks. A couple of q's though. The main support beam that runs vertically under the car, would it be alright to place the jack under the bolt and not where it 'bubbles' where it's supposed to be?
Sorry, but I want to be absolutely positive before I get under a lifted car!
Old 04-10-2003, 12:26 PM
Needs non-Maxima Friends
amixam98's Avatar
Buy some jack stands.
amixam98 is offline
Old 04-10-2003, 12:28 PM
Srt8ridin - I generally go for the mid point of that beam.
Old 04-10-2003, 12:31 PM
Str8ridin's Avatar
Alright, jackstands, midpoint and prayers...
Thanks fellas.
halfpol
10-17-2022 12:16 PM
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
acw
08-07-2015 04:20 PM
halfpol
08-05-2015 08:24 PM
Quick Reply: Lift points on the car?
