timing chain cover problems
Old 04-01-2003, 05:18 PM
delacruz_17's Avatar
I am not able to remove the timing chain cover. I have removed all the bolt and both pulleys. Everything that needs to be removed so that the cover will pop off, but it won't. I need some tips on how to remove the cover.
I have a 96, automatic
delacruz_17 is offline
Old 04-04-2003, 12:02 PM
any one got any tips
Old 04-04-2003, 01:53 PM
sinewave's Avatar
Whack it with a plastic-faced or rubber hammer. DON'T pry on it and don't wedge anything into the mating surfaces.
sinewave is offline
Old 04-06-2003, 04:01 PM
vexone's Avatar
I had the same problem when my water pump went on my 95 and i cracked the casing and it was leaking oil, so DON'T PRY.
Make sure... I know you took all 17 or 18 bolts out......but make sure you take off the oil pan.. it is somehow connected to the timing chain cover on the bottom..... An expensive lesson for doityourselfers out there.....
vexone is offline
maxprivate
Forced Induction
21
07-08-2017 09:48 AM
maxinout93
10-27-2015 01:29 PM
MaximaDrvr
08-19-2015 08:20 PM
Team STILLEN
08-10-2015 04:29 PM
Quick Reply: timing chain cover problems
