pathfinder throttle body
Old 03-01-2003, 01:55 PM
Father of the 00 VI
krismax's Avatar
When i put the pathfinder throttle body on will the 96 max frankincar midpipe with coupler fit on the 70mm throotle body,or is there a litte bit bigger setup they could give me ,but still fit my stock mass air flow sensor.thanks chris L.
krismax is offline
Old 03-01-2003, 03:10 PM
Jamsan's Avatar
just change the coupling on the TB side to something slightly bigger
Jamsan is offline
Old 03-01-2003, 05:01 PM
SLOW
Nealoc187's Avatar
Has anyone shown there to be any gains to this on a 4th gen? Or are you just experimenting?
Nealoc187 is offline
Old 03-01-2003, 07:00 PM
Father of the 00 VI
krismax's Avatar
Well my friend has a honda and even he says even lightly modded b16s gain 5-7 whp with 68 mm tb.60 mm for are sized engine is tiny .There has to be a gain of 3 or 4 horse at the least,we opened are cars up with intakes y-pipes and such but we are still forcing air thru same tiny tb.Even for 2 horse its worth it ,$75 2001 pathfinder tb and i work in a place that makes stuff for boeing,US gov apache parts ,and GE generator division. Spacer is no prob i will make two if your interested Nealoc187. And this might sound stupid but my goals are 12.9 NA.
krismax is offline
Old 03-01-2003, 08:32 PM
MaxWolf's Avatar
I interviewed at a place extrememly similar to that....Are you in Mass? Good luck with the install.
MaxWolf is offline
Old 03-02-2003, 04:12 AM
i SeE what you did therE
redmaxpa007's Avatar
Pathfinder tb on a maxima
redmaxpa007 is offline
trsandrew
17
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
REDinLV
10-18-2015 05:31 AM
msellas
09-23-2015 09:16 PM
bumpypickle
09-20-2015 08:22 AM
Quick Reply: pathfinder throttle body
