What does the fuel pump relay look like?
Old 12-16-2002, 04:34 PM
Krash513's Avatar
Im trying to find the fuel pump relay behind the drivers side kick panel. I know the color wires i need and i think i see them but i just want to make sure. Its a black circular cylinder with 12v and a number on it. Can Anyone help me???
Brett
Krash513 is offline
Old 12-16-2002, 05:10 PM
My other car is a Hybrid
Chunger's Avatar
You need to remove the larger plastic piece/panel just left of the dead pedal... It is mounted on the left side of the rectangular hole. There are 2 relays with a 10mm bolt holding it. One of them is the FP relay.
Chunger is offline
Old 12-16-2002, 06:35 PM
Krash513's Avatar
Ok the pain in the a$$ part is done, its all wired up and the wires are hidden, i started the car (thank god!) and now how long would it run at idle before it would die if the switch was off?
Krash513 is offline
Old 12-16-2002, 06:45 PM
jargoone's Avatar
Probably for less than 15 seconds or so. But why don't you just try it? It would be nice to know, and you won't hurt anything.
I've seen your many posts about this. I was wondering if there was a reason you didn't just wire a switch inline with the fuse rather than the relay. The only reason I could think is difficulty to find, but I really don't think it would be an issue. In any case, good job on the mod.
jargoone is offline
Old 12-16-2002, 07:02 PM
Krash513's Avatar
Well i chose the relay cause it was easier to find the right wire. You were right, about 15 seconds and she died, but now my power seat wont work.... hmmm so i guess ill play around tomorrow and see what i did.
Krash513 is offline
jmlee44
10-02-2022 02:13 PM
Miket2006
03-01-2021 03:55 AM
salty318
09-29-2015 01:21 PM
salty318
09-28-2015 07:22 PM
Quick Reply: What does the fuel pump relay look like?
