burned out light in seat heater switch ???
Old 11-29-2002, 10:11 PM
It's chrome alright...
2k2kev's Avatar
anyone know how to replace that, and what kind of light it is?
It's going to the dealer next week for something else, but I'd just as soon do it myself if it's not a hastle.
thanks
2k2kev is offline
Old 11-30-2002, 08:34 AM
big h's Avatar
you have a 2k2...it should be covered under warranty...get them to replace it..
big h is offline
Old 10-15-2003, 10:25 AM
ppetruccelli's Avatar
Seat heat switch light
I inquired at the dealer and they told me that they do not sell the replacement bulb. The bulb can be changed if you find it somewhere, but I had to change both switches at $37 Canadian each ($28us). The dealer informed me that the heaters usually don't work either if the bulbs are shot. I guess the bulbs complete the circuit.
thanks
ppetruccelli is offline
Old 10-15-2003, 10:51 AM
Kojiro_FtT's Avatar
It's under warranty, call them and tell them to order the switch and replace it. You can't replace that lamp, not without destroying the switch.
Kojiro_FtT is offline
Old 10-15-2003, 11:29 AM
2k2kev's Avatar
did you guys notice this thread is 11 months old? I got it fixed... thanks.
2k2kev is offline
Old 10-15-2003, 11:51 AM
bremner44's Avatar
bremner44 is offline
Old 10-15-2003, 12:15 PM
WVmax's Avatar
A little off-topic, but I have a question with the seat heater switch. Which way is more heat or less heat. I think the manual says opposite of what I was thinking. Do you rock it forward for the lower heat, or for higher heat? I thought the thicker line means more heat, but the manual says opposite. Just wondering. I have a 2000SE, btw.
WVmax is offline
Old 10-15-2003, 12:16 PM
Kojiro_FtT's Avatar
Old 10-15-2003, 12:19 PM
2k2kev's Avatar
the bulb does not complete the circuit...mine heated fine without the light. They also told me there is no way to replace the bulb and they just did the whole switch. If I had to pay I would have gone to a junk yard and gotten the switch myself.
The thicker line ('push' the switch) is "more heat", thinner line is less heat. I can barely notice the 'less heat' setting unless it's REALLY cold.
2k2kev is offline
Old 10-15-2003, 12:24 PM
kcowden's Avatar
11 months old.... how funny.
kcowden is offline
Old 10-30-2007, 04:42 PM
SpottyJ's Avatar
Anyone have a part number for the driver's side seat heat switch (2002 Maxima SE). My bulb is out (heat still works).
SpottyJ is offline
Old 10-30-2007, 05:46 PM
Booyah grandma.... BOOYAH
bigfatty's Avatar
4 years old, even funnier.
bigfatty is offline
Old 10-30-2007, 07:08 PM
jadedmatt's Avatar
call the dealership maybe? just an idea
jadedmatt is offline
Old 10-30-2007, 07:53 PM
tonyw's Avatar
I'm going to take mine apart and see what I can find. The heater works without the bulb. I'll post some details in the next day or so.
tonyw is offline
Old 10-30-2007, 08:02 PM
AnDyMaN's Avatar
lmk how it goes! ive heard about the expensive switches, and thought about replacing the light w/ LEDS if they went out. but i suck at led/soldering.
AnDyMaN is offline
Old 10-31-2007, 02:28 PM
SpottyJ's Avatar
Part Number for a 2002 is: 25500-50Y10
Dealer Quoted $56 (Stated List Price is $76)
Dealer would not provide part number unless there in person. Why? Dealer stated that they receive too many calls with people using them to find part numbers and then shopping elsewhere.
I got the part number from the RockAuto link above, then stated number to Parts Department who would then verify the number.
RockAuto has it for $46.79, plus $6.62 shipping, for a total $53.41
Dealer stated he had the same problem on his Maxima!
SpottyJ is offline
Old 10-31-2007, 04:19 PM
tonyw's Avatar
I fixed the bulb and it cost less than $2. Here's how to do it:
1 - Take the switch out of the center console. Be careful and pry it out gently.
2 - Disconnect the blue wiring connector and take the switch somewhere with good light.
3 - Using a small flat-blade screwdriver, gently release the 2 tabs holding the blue lower section to the switch assembly.
4 - Pull the blue section out (the sliding contact may fall out-no problem-see below)
5 - If you look at the blue section you'll see the bulb in a gray/blue rubber holder.
6 - The holder is press-fit to the two copper posts, Gently wiggle it off.
7 - The bulb wires make contact with the copper posts using contact pressure only
8 - With a jewler's screwdriver gently pull the bulb wires out of their holes paying attention to the way the wires were threaded through the holder.
9 - Carefully pull the bulb from its holder. Be careful around the actual bulb, it's sticky and the rubber holder can tear.
10 - Get a Radio Shack part number 272-1092 (12v microlamp) $1.69 for two.
11 - Take one lamp and feed its wires through the two holes in the base of the holder.
12 - Push the new lamp all the way down into the holder.
13 - Thread the wires back the way they were on the holder and cut off the extra wire
14 - Put the holder back on the copper posts with the lamp facing inside the switch
15 - If the black sliding connector fell out. Look inside the switch and place the connector back inside lining up the post on the connector with the U-shaped channel on the inside of the switch body.
16 - If the sliding connector is in correctly, you should be able to put your finger on it to hold it in place and rock the switch back and forth watching it move side-to-side.
17 - Rock the switch so the slider is to one side making the opening for the bulb as big as it can get.
18 - Slide the blub assembly as part of the blue section, back inside the switch with the bulb going up into the open section. Snap the two parts together.
19 - Put the switch back in your car and enjoy the new light!!
20 - This whole process only took about 5 minutes once I had the correct bulb.
tonyw is offline
Old 10-27-2008, 07:26 AM
g.sembhi's Avatar
took me five minutes too
g.sembhi is offline
vingodine
45
05-21-2016 12:46 PM
homeyclaus
09-03-2015 06:15 PM
Samedi
08-13-2015 04:05 PM
98nismomax
08-13-2015 12:15 PM
kjm900r
08-05-2015 07:14 AM
Quick Reply: burned out light in seat heater switch ???
