no sound coming from radio...
Old 09-28-2002, 06:56 PM
tisme's Avatar
hi, this is my first post so if i do something wrong, sorry!
anyway, i have a 97 maxima without the bose system. I installed an aiwa cdc-x417 receiver that i took out from my old car. Called crutchfield and ordered the wiring harness and antenna adapter. After following the instructions and installing the receiver i tried playing the radio. There is no sound that comes out, FM or AM. There isnt even static that is coming from the speakers, and the display doesnt show sound either. I have no idea why it doesnt work. Playing a cd works perfectly so there's nothing wrong there.
I tried calling crutchfield, but it didnt help.
has anyone encountered this problem??
tisme is offline
Old 09-28-2002, 07:48 PM
BeauBlanco's Avatar
Interesting problem RARE. Do your radio stations scroll like a count down when searching for a station? I would double check your antenna connection, and then investigate if your tunner (radio section is shot) I've only seen that once before. Good luck
BeauBlanco is offline
Old 09-28-2002, 08:13 PM
tisme's Avatar
all the connections are tight...when i turn the radio on the antenna goes up but no sound and it doesnt lock on a station when i seek. The crutchfield guy says it could have something to do with the ground wire?!?!
the tuner should work because i just took it out of my old car and it was working perfectly...
with the antenna adapter, i plugged the 2-pin wire from the car into the adapter, and pluged the male connection to the headunit. There is also a female pin connection not being used, is that right???
tisme is offline
lux97Max
09-04-2015 05:42 PM
jfl330
09-04-2015 01:44 PM
TheMafia
09-04-2015 08:26 AM
sdotcarter
09-02-2015 09:53 PM
A32goldylocks
09-02-2015 06:39 AM
Quick Reply: no sound coming from radio...
