what happens if you don't replace the cv joints?
Old 09-18-2002, 10:11 AM
mohfo's Avatar
mohfo is offline
Old 09-18-2002, 10:14 AM
voltman's Avatar
Is something wrong with them?
voltman is offline
Old 09-18-2002, 10:24 AM
Old 09-18-2002, 10:29 AM
Minister of Silly Walks
mzmtg's Avatar
Re: what happens if you don't replace the cv joints?
they get louder and louder and then they break completely.
mzmtg is offline
Old 09-18-2002, 10:30 AM
Lime's Avatar
The world stops existing!
Sorry.
Anyway, what will happen is that your axle will fall apart.
Lime is offline
Old 09-18-2002, 10:35 AM
I'm needing a caw
Jeff92se's Avatar
You will get mad camber YO!
Jeff92se is offline
Old 09-18-2002, 10:47 AM
thebigsadler's Avatar
what will happen if you dont put your wheels back on your car and take the car off jacks stands and drive away?
thebigsadler is offline
Old 09-18-2002, 12:16 PM
max1ma97se's Avatar
bye bye drive axles. umm go to pep boys and by the rubber cv boot for 15bux each and get your hands dirty and save yourself couple hundred dollars on new drive axles
max1ma97se is offline
Old 09-18-2002, 12:23 PM
Ummm it drives really really rough cause the rotors are metal and like you've got no rubber on the road. I think pretty sparks fly out from it too. I watch cops on Saturday nights so I know this.
Some day I want to try this to see if the cops show is really showing the true thing with the pretty sparks. I think they edit the sparks in just for TV, but who knows.........
I'm still trying to figure out why my finger doesn't lite up when I put it in the same hole as the ciggy lighter goes in...... Strange no?
Old 09-18-2002, 03:13 PM
ivelweyz
nothing, you won't be able to drive away. Really bad analogy attempt...
Old 09-18-2002, 04:23 PM
living out of a maxima...
JeffesonM's Avatar
c'mon... cut him some slack here. it was a good attempt, but just did not materialize into a good analogy.
JeffesonM is offline
Old 09-18-2002, 04:59 PM
costcowholesale's Avatar
sounds like it'll be in fast & furious 2!!
costcowholesale is offline
Old 09-18-2002, 05:39 PM
mzmtg's Avatar
So tell me, is ignorance as blissful as they say?
mzmtg is offline
Old 09-18-2002, 06:50 PM
Lime's Avatar
CV joints, CV boots, yeah...they're alllllllllllllllllll the same.
Lime is offline
Old 09-19-2002, 12:43 AM
jay_johnson's Avatar
jay_johnson is offline
Old 09-19-2002, 04:09 AM
Kashoggio's Avatar
One of the most impotanat compnents on a Fwd car are the Constant Velocity joints. The CV joints are used to transfer torque at a constand speed with a operationg through a wide range of angels. If you see your Cv boot has split,inspect it as soon as possible. If you notice any foamy or mily apperance that will tell you that water is in the join. If you feel a gritty feeling in the grease that means that you have dirt inside the CV joint if you notice any of this you have to replace the whole CV joint. ON a side note if you notice vibration in your car it could be most likely due to your wheels being not balanced but it could also come from your CV joints. IF the vibration occurs at high way speeds but it comes and goes its your CV joints. The easiest way to know if you have bad Cv joints is to go in reverse in a tight circle, you will hear clicking
Kashoggio is offline
Old 09-19-2002, 10:33 AM
timmax's Avatar
CV's go bad very slowly
I'm 35 yrs old and been driving since 15 1/2, always a FWD. Probably half of the miles I've ever driven have been on vehicles with leaking/cracked cv boots. You can go years without fixing them, as I have. But I am in a very dry climate, southern AZ, so it depends on your situation. When we do fix them out here, we always replace all 4 boots, actually we just replace the entire axle on both sides.
timmax is offline
maxocar
08-21-2015 12:57 AM
soon2ownmax
08-13-2015 02:19 PM
kirkhilles
08-08-2015 10:53 AM
classymax420
08-06-2015 06:35 PM
Quick Reply: what happens if you don't replace the cv joints?
